Door Handle Accent Lights Install
wow I am so stressed out. How the hell did you guys get everything to fit. I have been working for more than an hour and cannot get the LED and door lock to fit. I've been grinding away at both; I'm not even sure the led will still light up. I just might have to give up and search for a new plastic lock cover as there is already a hole in mine now :-(
what i notice is u just gotta cut a bunch off the metal part for it to fit nice in the plastic, it took me more then an hour...for 4 hours for one cuz i had the wrong bit for the dremel...but since i bought a better bit did it in like 30 mins...good stuff...so just dont give up and you'll get it for the little led you just have to take all of the clear stuff off...thats how i got mine to fit...just the led and the wires you should have to it fit then. took me a few days just to finish everything..so dont think its like a two hour project take some time on it
damn i went thru so many of those ____in superflux LEDs...i know i'm a newb at this for sure!! and now there's no more white ones =(!!! is there an easier way to take off the plastic covering??? when i try to take off the plastic the wire ends up coming off the LED which then i cant even fix it cuz its so close to the LED itself
Ok well I have officially decided there is know way im going to try to cram a superflux in the handle again. However I definatly think one of Ozniums 5mm leds would fit perfectly for me. i just dont know if it would be bright enough to be worth it... thoughts?
