tC Tech and DIY Info for the Scion tC
HID Retrofit (Custom)
Old Sep 22, 2005 | 09:41 PM
  #181
SassyScion's Avatar
I understand what you're saying. My worry would not be changing the bulb from burning out, rather from them breaking. These bulbs are very fragile (I already broke one before I even got half way finished with the install ) and with the roads around here, I see them getting broken before they would burn out.
And for me, I do drive a lot at night... as much as, if not more, during the day. I'm also worried about my bi-xenon solenoid since I drive with my hi beams on, but maybe my lights will be so bright I won't even need my hi beams!
Old Sep 22, 2005 | 09:53 PM
  #182
freeflowing's Avatar
bixenon. how are you going to wire that half up????
you probably also wont need your high beams much
Old Sep 22, 2005 | 10:31 PM
  #183
maximus96's Avatar
i also don't want to seal the ignitor in because i worry that i may have to change the bulb at some point before it dies from old age. but i guess if you silicone it'll be easy to remove when you have to. i may do that after i wash it this weekend to see how well it holds up. i'm pretty confident that i don't need to seal it up anymore than what i already did.
in regards to the bi-xenon, its not that difficult since the tc has separate wiring for high beams so you don't need a diode. but on a projector like the E46, you'll need to wire capacitors.
Old Sep 22, 2005 | 10:46 PM
  #184
SassyScion's Avatar
As far as the bixenon wiring, I have a diagram from HIDPlanet to follow.
Hey maximus-
you have the CCFLs from Umnitza right? Did you wire it into a dimmer switch or just into your parking lights?
Old Sep 23, 2005 | 01:48 AM
  #185
maximus96's Avatar
Hey maximus-
no i acutally used a set for E46...they fit the E46 bezels pretty well. i wired to parking lights so they blink when i arm/disarm my alarm.
Old Sep 23, 2005 | 06:19 PM
  #186
hey maximus
did you splice your wiring or did you make a connector for the angle eyes. also did you know the e60 are using fiber optic angel eyes.
Old Sep 24, 2005 | 01:21 AM
  #187
maximus96's Avatar
Originally Posted by freeflowing
hey maximus
i spliced it. i was going to rig up something to plug into the 194/168 socket, but decided to splice it and leave the empty socket plugged in to avoid water leaking in. what year is the E60? i never heard of that number, is it the new one? but all bmw angel eyes are fiber optic.
Old Sep 24, 2005 | 06:02 PM
  #188
2005 BMW 5 series e60 and yes from what i understand they are going fiber optic
Old Sep 30, 2005 | 03:22 PM
  #189
maximus96's Avatar
well ****...last night i took the car out after dark and saw condensation inside the passenger side light. it blocked most of the output to the ground on that side. the driver side is fine.
on sunday morning after i washed and dried the car, i didn't see any water getting inside the lights, but some water did get in the engine bay from the gap of the hood. that made me uncomfortable so i went and bought some weather strips from autozone to line the two sides of the hood.
i'm not sure what caused the condensation in the passenger side light. i have to see if it leaves any streaks or marks after it dries. it didn't rain yesterday, it was rather a very warm day. i'm thinking its because the car was parked outside all day at work, then i parked it in the garage when i got home at 6, the air inside the headlight was still warm compared to the cool air outside when i took it out at 8. i dunno, i have to research it on hidplanet now...
Old Sep 30, 2005 | 07:35 PM
  #190
hmm keep us updated maximus
Old Oct 9, 2005 | 04:43 PM
  #191
Poison's Avatar
Sup man Nice job, I was just wondering are their different colors for that "Heat Resistant" paint or w/e you used? Silver would look like ____ on a Flint Mica.
Old Oct 9, 2005 | 11:44 PM
  #192
maximus96's Avatar
Originally Posted by Poison
Sup man Nice job, I was just wondering are their different colors for that "Heat Resistant" paint or w/e you used? Silver would look like poop on a Flint Mica.
duplicolor makes a whole bunch of color for their High Heat paint. i'm sure something will go well with a FM car.
Old Oct 14, 2005 | 12:31 AM
  #193
sVperbeast's Avatar
Default Keychain
Hey, excellent job on the write-up!
One question though... Do you have a problem with the keyless entry remote flipping the headlights on and off when you unlock/lock the doors, or is the wear that that places on the bulbs negligible? I can't think of an easy way to re-wire that system unless there's a way to disable it...
Old Oct 14, 2005 | 02:07 AM
  #194
maximus96's Avatar
the alarm blinks the parking lights. i have a viper and it doesn't blink the headlights. the scion keyless entry blinks the signal lights. unless you got some other system your headlights shouldn't flash. you do NOT want your HID bulbs to turn on and off so fast. it kills the ballasts prematurely.
Old Oct 14, 2005 | 11:38 PM
  #195
sVperbeast's Avatar
Well that's pretty strange!
The signals flash if you aren't changing the locks, but if I lock/unlock it, then the headlights stay on for maybe 5-10 sec.
This could turn into an interesting project...
Old Oct 17, 2005 | 06:05 AM
  #196
Jlevi's Avatar
AWESOME PROJECT!!!!!!!!
Old Oct 17, 2005 | 06:08 AM
  #197
Nick_JleviSW's Avatar
THAT is UNBELIEVABLE!!! The best lighting project I HAVE EVER SEEN!
Old Oct 19, 2005 | 01:05 AM
  #198
leov36's Avatar
hey maximus i have some questions about your eyebrows, in the pics it shows a clear bar with the white leds wired into it , is this bar part of the tc's headlight assembly thats underneath the clear brow that you removed in one of the first pics of you post,, or is this a seperate peice you bought somewhere else?, if so were did you get it? also what kind of leds are you using in your brows. thanks.
Old Oct 19, 2005 | 04:32 PM
  #199
maximus96's Avatar
i just made that bar out of acrylic curtain rods from homedepot...$2 for a 3' piece, heat and bend into shape. i just used plain 3mm white led, i forgot the mcd rating. i don't think its bright enough. at some point i'll redo it and used superflux leds. i'm too lazy to redo for now...
Old Oct 19, 2005 | 06:09 PM
  #200
maximus
with your setup
do your hid shake noticably when you drive?? where did you buy the springs you used for the bolts ??? also are your lights still fogging???
