HID Retrofit (Custom)
Originally Posted by Poison
This just came to mind, Where happens to the City lights once your retrofit is done?
for those wondering how would you rig up projectors vs how maximus did his heres a pic.
hidretro was generous enough to show me their method. the pic show they are using the silver adjustment screw on the oem headlight which means the only adjustment you need to make is up or down and thats it!!!!
which by the way i didnt do on my retro fit.my adjustments are made independent of the reflector .
in the pic below hid retro used a black sleeve to center the light
I have some Existing DD Eyes on my stock lights....would I have to remove them in order for projectors to fit in? If so what a waste
Say I'll most likely be getting a E46 projector....what are you comments on those? Thanks.
i favor japanese stanley projectors myself, but the E46 are decent projectors, go for the bi-xenons.
same here .definitely remove them during the retro fit or you will be kicking yourself . screwed one of my halos up during the intall and now i have to take one apart to remove and replace soon.
maximus,
i was worried about the adjustments too but he claimed to me that he will redo them if he'd screwed up on that part. i also got a quote from him for 580 bucks if i provided him the projectors and headlights so im kinda of interested in seeing his work since hes done so many retros. that black sleeve hes using is the key hes says to successfull reto fits hes done for the scion tc.
my retro turned out good but i didnt have any level ground were i live the beam is slightly to low so i have to re aim mine this weekend. all my adjustments are inside the head so i have to take mine apart to reaim mine as well but no fogging so far on my end yet
maximus,
maximus,
maximus,
usually don't you place the original housing on a table shine it against the wall and mark off the original cut off with tape then when you're aiming the projectors before you cement them in put the housing in the same position then make the cut off in the same place as the original?? I'm guessing that's how they do it when you ship them off to get them done? They probably keep the housing in a vice the whole time so it doesn't move-any ideas guys?
http://store.summitracing.com/defaul...6&autoview=sku
they are all 18 gauge :T sad T__T i gotta make my own now T__T
Originally Posted by raWr215
http://store.summitracing.com/default.asp?target=egnsearch.asp&N=400304+311186&autoview=sku
yeah they are 18 guage but it was sort of a guide to how to build your own harness and like i said i had 12 guage wire at my job so i i just swaped the 18 for 12 thus it helped me build my own harness.
your harness needs to look like this. ignore the the bulbs and conectors they show for the ballast they show in the pic
Guys check this out on ebay if anybody interest on them
http://cgi.ebay.com/ebaymotors/TSX-P...15408967QQrdZ1
I have 5000mcd led's. When I hook them up in a series they all blow out tho. And I cant seem to hook up more than 4 at a time? Do I need a resistor to be able to hook up more than 4 at a time or can I wire them up a different way?
I've seen a lot of ford focuses with HID's - anyone every look at purchasing those HID's? I imagine they are cheaper than BMW, Mercedes, etc
I just sold my "ghetto style" HID's in hopes of a true retro fit or a aftermarket projector headlamp
i *think* the focus uses E55 projectors. i have no idea if true or otherwise. i remember reading a thread over at hidplanet where somebody bought the focus light from a junkyard and the ballast was still attached at the bottom and was not charged for it....lucky bastard.
