HID Retrofit (Custom)
Originally Posted by Hitm@n
1. I have a couple questions. Like when mounting the projectors how do u know there being mounted level? How would u test them.. i mean if iam in my house how would i plug them in?
2. when prying the headlights open are they very fragile?
3. if i have an s2000 headlight (the whole light) does that have a bezel. (which i can use?)
4. And wiring in angel eyes? where do i wire them into? Do i need anything else?
Iam sorry but iam getting everythign together and just wanetd to know these things b4 i started. Any other advise is also great.
http://hidplanet.com/forums/viewtopic.php?t=3908
When opening the headlights you have to make sure you have baked them well. They do take some effort in pulling them apart, but use common sense. If it feels like they aren't going to move at all, the glue probably hasn't melted yet.
Uhhh I'm not sure about your s2000 question, but I can answer your one about the angel eyes. Wire them to your parking lights. The angel eyes, however, are VERY fragile, so be careful not to bend them or pull the wires too hard.
i mark the cutoff line of the other unmodified headlight on a wall and align the projector to that. i use an old computer power supply to power anything 12v. to power a ballast, you'll need on that has at least 8 amps on the 12v rail. most already do.
the headlights are somewhat fragile from being heated up. they made crackling sounds when i took mine apart.
depending on the year, the s2000 have different bezels but they're just a chrome trim piece that fits right around the projector glass. you might want to get something else that covers up the entire projector and the nuts and bolts. also, be adviced that the s2000 projector is part of the entire headlight bracket and they don't come off like the tsx or other projectors. you'll need to cut away and rest of the bracket and drill your own mounting holes. its not difficult and is definately worth the effort for the s2k projectors.
you can wire the angel eyes to your parking lights. you probably don't need a relay but for $5, why risk it?
oops, projectD already answered most of the questions
didn't make much progress on the retro these past few days. i was test fitting again the other night and realised i mounted the projector too low. i'll just elongate the mounting holes and it should be a quick fix. i'm getting a free pair of E46 single xenon chrome shrouds so i'm waiting for that to arrive before making more adjustments. and i've been busy painting the radiator cooling plate from doc isotope since that'll be an easier project to finish first.
Parts list:
2004 Acura tsx projectors
D2s bulbs from hidplanet.com
I had previous ballast and wiring from a plug and play kit
Dremel
Caulk
Misc. hardware
And time!
very nice! why did you need to use caulk? if it was for a sealant, caulk doesn't hold up well against water...
Originally Posted by freeflowing
maximus96
are you using relays with hid setup or are you using the 9006 adapters. please tell because this is the only thing thats holding me up from starting this project on my own
so do you can i use a kit that has the promper fuse rating and also has relays already built in to protect the stock wiring
check out this harness on this liknk to see what im talking about
http://www.xenondepot.com/product.php?product_id=50
i guess thats a fair price for a harness. i usually make my own, the parts cost no more than $10... i use a 30amp fuse to the battery, then 15amp on each of the two power wires for the ballasts...i don't know if the xenondepot harness include the additional fuses. its redundant and you can easily add those yourself...again, cheap insurance.
I did use clear silicon, but i used a caulking gun to dispense it. so thats where i got confused. so i did do it right. i think that back of the projector is where my water is coming in. where the rubber seal is.
Originally Posted by ProjectD
what did you use to cut the sheet metal?
Originally Posted by whitexa
hm... how much would it cost if i ask u to help me make one??
