LED Swap (05-06 HVAC w/Circuit MOD)
Originally Posted by johnnyTCblaze
Check this out. It looks like there is another way to fix the dim blue/white console problem. This was on clubsciontc. Heres thie link to the topic, its on pg 12: Courtesy of Viro!
http://clubsciontc.com/modules.php?n...=asc&start=165
Have you seen this engifineer? What are your thoughts on this and do you know where I can get these bridgable jumper cables?
Johnny TCblaze.... the way to fix this problem as i posted on clubsciontc.com seems to work fine for white.
I tried with blue and the difference IS noticeable. The way to do it with blue is as enginfineer figured and pulls less current from the board.
Either ways works just fine for white... recommend being really carefull with the LCD, it breaks very easily
Originally Posted by jmiller20874
For the resistors, if I wanted to get surface mount to keep an OEM look, what size would they be? Thick or Thin Filmed? Mouser.com has SMD resistors starting at $.08 a piece.
To pick your smt resistors, a good way to double check is measure the ones on the board and then look at the dimensions on the datasheets.
And do listen to viro on the LCD... those are very fragile.. and around 400 -500 bucks seeing as how you have to replace the entire unit if it cracks. And I figured the difference in brightness would be washed out with the whites, so that makes them a little easier to mod. For the ones I am doing for people I still do it the same as the blues since I have it all planned out now and have the resistors bent and ready to go. It only takes me a few more minutes to do it that way and keeps a standard design for all the ones I do. But, if you do your own and use whites it will save you some time to do it the way viro does it, especially if you havent spent endless hours building circuits on perfboards as I have through many projects
Ordering parts this weekend and doing a center console late this coming week, so I will use it as a template to perfect the peices and then let everyone know how much.
I'm curious on what type of leds everyone used on the gauges? Did everyone use the 0603's from ebay or did you use a larger type. Mine that i got are really tiny, they are just little specs. Any help would be appreciated before I start pulling stuff apart.
To those that sent me pms about this, sorry it took so long to respond. I was out of town all week. The ones from LC-LED (the power tops) are the exact package to replace the stock LEDs. Make sure you have some tweezers or some small needle nose pliers available.. because they are tiny.
Originally Posted by KINGxOFxSKA
engifineer you should find out how to change the LED's for us automatic guys shift area..... just a thought... new idea?
