tC Tech and DIY Info for the Scion tC
LED Swap (05-06 HVAC w/Circuit MOD)
Old Aug 21, 2005 | 10:45 AM
  #61
tekniq's Avatar
engifineer: you sir, own all!
Great work on the fix for this, I bow down in reverence and humility to your skills :p
Old Aug 21, 2005 | 03:17 PM
  #62
ScionDad's Avatar
Originally Posted by killer4605
does anyone have any spare red, blue, or green LEDs? i need 2 (want to change the 2 LEDs on the AC and other button.) will pay $$ or trade 2 white LEDs
I have 2 blue LEDS - PM me and I will mail them to you.
Old Aug 21, 2005 | 05:07 PM
  #63
engifineer's Avatar
Did you recieve the console back in one peice? Thought I would check, they were supposed to have it there no later than friday.
Old Aug 22, 2005 | 02:37 PM
  #64
ScionDad's Avatar
I got it and installed it last night. That is just SICK. Wow, the blue just works perfect and punches out. Thanks again Engi -
Old Aug 22, 2005 | 03:28 PM
  #65
z-lite's Avatar
Shipping my console and gauges tonight for a white LED mod :D Although I'll be tC-less for a week
Old Aug 22, 2005 | 03:46 PM
  #66
engifineer's Avatar
Your LEDs should be at my house by tomorrow at the latest.. so we are all set!
Old Aug 25, 2005 | 01:51 PM
  #67
engifineer's Avatar
I came across something interesting during one of the console mods I performed the other night. When replacing the resistor in series with the clock LEDs, they ended up too dim. After doing some testing I figured out why. Due to tolerances in circuit components, the regulated voltage on that particular board was 7.90V as opposed to the 7.95V I have seen on other boards. This may seem in-significant, but the LEDs drop right at 2.643V each, adding to 7.93V. So simply replacing the resistor with a jumper allows for just enough voltage to power the LEDs and make them bright enough to illuminate the clock as long as the power supply is providing more than 7.93V. So, in the case of the one I mentioned the 7.90V causes major dimming issues. The LEDs barely light at all.
So, I added a quick fix, which is basically the same design as the other groups of 3 LEDs. I performed the following:
1) Cut the trace between the first LED and the second one.
2) Connect the Cathode of the first LED to the Cathode of the 3rd LED using a 680 Ohm resistor
3) Connect the anode of the second LED to the anode of the first LED using a 330Ohm resistor.
This actually came out a little brighter than needed, but looks great. I may raise the value of the resistors to around 800 and 430 to make them match the odo a little closer.
So if anyone comes across this issue when trying this mod, this is why. I reccomend doing it this way the first time to avoid repeated disassembly and assembly. I will post pics of the next one I do this way to make it easier to follow.
Old Aug 25, 2005 | 02:40 PM
  #68
Fsu1dolfan's Avatar
^^^^Anything on the HU.....just curious because i may have some time this weekend do to this damn tropical storm/hurricane...then again i might not if i lose power!!!
Thanks
Old Aug 25, 2005 | 03:09 PM
  #69
engifineer's Avatar
Thanks
Not yet. My girlfriend and her son moved in with me last weekend from OK. So we are unpacking, re-arranging, etc. Plus I have had one hell of a hard week at work and have done 2 gauge and console conversions with one left to go today.. so my week has been tiring to say the least But, I hope to get to it soon!
Old Aug 25, 2005 | 03:13 PM
  #70
ScionDad's Avatar
Thanks
Congrats on the move in....I hope all goes well.
Old Aug 25, 2005 | 03:17 PM
  #71
engifineer's Avatar
Thanks
Thanks! It is great to have them living with me... so something shiny and a house are in the works next I guess :-P
Old Aug 25, 2005 | 03:22 PM
  #72
Fsu1dolfan's Avatar
Glad to hear.....No rush....try to relax some!!
Old Aug 29, 2005 | 03:30 AM
  #73
007Gecko's Avatar
From what I gather this only needs to be done if you are wanting to use White or Blue LED's? I want to change mine to Red and would like to skip all this if necessary.
Old Aug 29, 2005 | 01:37 PM
  #74
engifineer's Avatar
you should be ok with red.
Old Sep 3, 2005 | 03:17 AM
  #75
KINGxOFxSKA's Avatar
Unique Scionikz
Sent my center console to engifineer to get the fix done. All I have to say is WOW! It is bright and sexy. THANK YOU! :D
Old Sep 4, 2005 | 03:16 AM
  #76
Unique Scionikz
bbbump
Old Sep 4, 2005 | 03:55 AM
  #77
engifineer's Avatar
Glad you like! The white turned out nice with the head unit, nice choice of color :D Thanks for the kind words as well!
Old Sep 4, 2005 | 08:52 PM
  #78
Fsu1dolfan's Avatar
Just checking up on any news about the HU???
Old Sep 5, 2005 | 01:16 AM
  #79
engifineer's Avatar
Not as of yet... but still trying to get around to it.
Old Sep 6, 2005 | 01:21 AM
  #80
johnnyTCblaze's Avatar
Check this out. It looks like there is another way to fix the dim blue/white console problem. This was on clubsciontc. Heres thie link to the topic, its on pg 12: Courtesy of Viro!
http://clubsciontc.com/modules.php?n...=asc&start=165
Have you seen this engifineer? What are your thoughts on this and do you know where I can get these bridgable jumper cables?
