tC Tech and DIY Info for the Scion tC
Mirror Turn Signal Change
Old Jun 14, 2005 | 08:01 PM
Kaeon's Avatar
Originally Posted by toastbox
FYI....as good as that looks, it's also illegal. Side markers are *required* to be amber/orange. Some states might fail your safety inspection, so be cautious.
It does look sweet though! Great job guys!
Not 100% True, Some states allow Orange/White
Old Jun 14, 2005 | 08:03 PM
toastbox's Avatar
I thought that was on the parking lights only....maybe I have that backwards
Old Jun 15, 2005 | 04:48 AM
David616's Avatar
What kind of bulbs did you use for your front turn signals? Where did you get them from?
Old Jun 19, 2005 | 03:18 PM
The_Instigator's Avatar
I used Raybrig R132 available for $10 each at www.racinglab.com . They have a hyper white look that match my luminics hyper whites perfectly.
Old Jun 19, 2005 | 05:15 PM
its_ikon's Avatar
i would do this, but i don't want to cut up something that works perfect.
Old Jun 19, 2005 | 07:19 PM
Kaeon's Avatar
LOL, Sam you will end up doing it!!
Old Jun 20, 2005 | 05:47 PM
itstdt's Avatar
I have taken the lens out... but is cutting the only way to get to the LEDs? Can I use the leds which are used on gauge cluster? It seems to be a surface mounted LED on a metal base which is used to connect the + and -.... Thanks
Old Jun 20, 2005 | 07:07 PM
The LEDs are surface mount that are stamped onto the metal inside the housing. You can try surface mount LEDs, but I have a feeling they wont be bright enough. They are also more expensive than standard LEDs and are header to get in a color you might want. If you use them, let us know how they work.
Old Jun 20, 2005 | 07:17 PM
itstdt's Avatar
so... is using a cut bit the only way to get to the LEDs?
Old Jun 20, 2005 | 09:16 PM
After doing another car and redoing mine a couple times, I dont see how else to get to the LEDs. If you come up with something let me know but I dont think theres another way in there.
Old Jun 21, 2005 | 01:26 AM
Kaeon's Avatar
Hmm ok today I noticed that my driver side leds will not light up at all, and my passenger side only lights up one LED I have no idea what happened...
Old Jun 21, 2005 | 05:15 PM
itstdt's Avatar
did u check y it is not working?
Old Jun 21, 2005 | 05:47 PM
Kaeon's Avatar
I talk to The Instigator he said the same thing happened to him. He said he thinks its from the shock of the doors opening and closing. Im trying to find some better LEDs to use. Some OEM style ones.
Old Jun 26, 2005 | 07:25 PM
CatalepsicFox's Avatar
I wonder why don't you put that whole signal casing into the oven like what people do to make angel eyes in with their headlights.
Old Jun 27, 2005 | 12:47 AM
It doesnt use the same kind of adhesive. The mirror housing is put together with some kind of epoxy that bonds the halves together.
Old Jun 27, 2005 | 01:33 AM
stick_1NZ's Avatar
good job on the DIY. do these LEDs stays on all the time or blinks with your turn signals? suggestion: why not try mounting the LEDS into a bread board and sodder them that way it's more stable. just my $0.02.
Old Jun 27, 2005 | 02:56 AM
Kaeon's Avatar
They replace the OEM Orange Leds, The tC side mirrors are used for turn signals, So they blink when you signal..
Old Jun 27, 2005 | 11:02 PM
I think you would have to get in there to really understand what is needed. I dont see how using a breadboard would help at all. You are soldering an LED right to the metal in the housing. Maybe you can elaborate because I dont understand how your idea would help.
Old Jun 27, 2005 | 11:44 PM
Kaeon's Avatar
Have you located any LED's that would work better?
Old Jun 28, 2005 | 01:26 AM
Since squeezing the silicone around the base of the LEDs after soldering, I havent had any more die on me and its been about a month. Im going to stick with the ones Ive been using as it seems to be working OK. I guess its just enough to help them from getting shaken around too much when the doors close.
