Transmission Flush (Manual, Redline MT-90)
Originally Posted by The_Instigator
Originally Posted by yamaha16bw
So you fill it up till it reaches the top?
27mm for the top reverse sensor 24mm for the bottom. the front is the fill, the rear is the drain, or maybe because i lifted the front of the car on jacks. it wasn't that hard to do (if i had all the parts at once) and to be honest i haven't notice a huge difference but it is smoother. at least if anything I'm averaging 28MPG-32MPG
I just changed my gear oil with MT-90 and I absolutely love it. It was so smooth right out of the shop. I had a local shop change it for 20, in about half an hour. It is well worth changing to this oil.
im so happy 100% everybody is saying the same thing because i have 3 bottles of it sitting next to me right now - im just waiting for a good time to change it. I think im going to change it next weekend or the weekend after that.
yeah.. i accidentally torqued the drain plug a little too much after i was done (making sure they were tight and stuff)... and uhh... crushed the gasket..
... it got a leak and yeah.... had to open that sucker up to replace it....
my friend helped me remove it and plugged it with his finger while we quickly replaced the gasket and put the plug back on without losing too much oil (and the tranny case was still abit hot...
thank you dave at stevens creek scion for saving me from my stupid mistake..
yeah.... don't over tighten it.
yeah.. i put ALOT of force into it..
.... car was lifted up.. used my body with a fairly long wrench...
oops... yeah.... umm... i wish i could give you numbers,,, but use your nest judgement... i wasn't thinking at the time when i did it.
I have the s/c in my car. I was not able to get my hand down to where the sensor is. If I would have known that before hand I would have performed the swap before my s/c was installed a few weeks ago. Please put that in your top post.
Originally Posted by SquallLHeart
yeah.. defiinitely worth it in my opinion.
cost me about $25 to do?
