xA Tech and DIY Info for the Scion xA
Ground Wire Kit Install (Homemade)
Old Jun 19, 2005 | 05:22 PM
  #121
Boricua's Avatar
For those who want to see how to do it on a tC, here is how I did it: http://www.cardomain.com/ride/861695/3
If you want bigger pics, email me at castro.fernando@comcast.net and I'll send you the full-sized pics.
Old Jun 24, 2005 | 05:14 AM
  #122
EEk13's Avatar
ah, ok finished the install last night and took pictures this afternoon..
here's the wide view of the finished job..
there are few more pics at the link below
http://www.imagestation.com/album/in...?id=2130139868
I got all my supplies from knukonceptz.com and paid about $27 for everything shipped. I also bought a battery terminal to fancy up the install which cost $12. So if you don't want the battery terminal, cost of supplies to do this mod is under $20 (not counting the crimping tool). I even had left over wire to swap out the stock grounding wire that hooks up right behind the headlamp (I bought 8' total vs. the recommended 7').
The total time I spent on this project from first wire snip to ignition start up was about 3 hours. I was being extra extra careful though - you know what they say, measure twice, cut once. Well, I measured thrice! Most of the time was spent trying to UN-crimp the stock ground cable from that unique connection by the headlamp (that was a PITA!!) If you are gonna do that, see if you can get a new replacement from Toyota or something instead.
All told, I could do this for someone else in about an hour given they use the stock battery terminal and don't want to replace the stock ground cables.
That being said, I took her for a spin around the block and I swear I can feel a difference. Of course, that could just be the feeling of a job well done so...
Still, very happy with how it turned out. Big *Thank You* to Mikochu for the instructions and to Tbone587 for the suggestion of getting the supplies from knukonceptz.
Old Jun 24, 2005 | 05:33 AM
  #123
EEk13's Avatar
my pic link didn't work.. ah well..
please see the image station link for that pic and others.
Old Jul 1, 2005 | 10:39 PM
  #124
Chemical_Whore's Avatar
i just did my TC. i went from the bolt holding the coolant tank to the fender, to the bracket holding a sensor down on the front passenger side of the engine block, to the drivers' side coil pack bolt, to the negative terminal of the battery, to the forward most bolt on the suspension.
Old Jul 2, 2005 | 12:56 AM
  #125
boostedscion's Avatar
whoa thats some good info. Thanks for the write up
Old Jul 3, 2005 | 03:46 AM
  #126
Update: After a full day of driving, i notice no difference at all. . . .
Old Jul 18, 2005 | 07:46 PM
  #127
fishingexpert87's Avatar
guys, i have a tc and i bought ground wires like this http://cgi.ebay.com/ebaymotors/ws/eB...tem=7986795592 ,
I wanted to kno if its the same hookup points? the manual that came with the wires were so crappy. it doesnt even say ne thing. plus, am i supposed to disconnect the wire thats on the negative of the battery and places the new ground wires instead?
thank u!
Old Jul 18, 2005 | 07:49 PM
  #128
EExA's Avatar
Chemical some will some won't I know after a year and 12000 miles on our xA the performance has dropped off. This is not some kind of mystery horse power maker, the best it will do is smooth the electrical out and strenghten the grounding. If yours wasn't flakey in the first place nothing really will happen.
Old Jul 20, 2005 | 02:49 AM
  #129
EExA, that sounds about right. but the way everyone was talking, i was figuring that was an issue w/ our cars. it didn't cost me a dime to try it though because i had the 8 gauge wire laying around from an amp kit. i'd have been ____ed if i spent $50 on it though. lol
Old Jul 27, 2005 | 10:05 PM
  #130
Maguyver's Avatar
cool
Old Aug 27, 2005 | 01:35 PM
  #131
chadfo's Avatar
BUMP!!!!
Old Sep 5, 2005 | 03:56 AM
  #132
bblhed's Avatar
First off let me say that has to be one of the best set of instructions I have ever seen!
Next let me post some bad instructions. If you want to crimp 4 gauge or less ring terminals I seguest not using a crimp tool at all, I recoment getting a short pair of bolt cutters (12" ones will do). Then get the longest 3/8 grade 8 sholder bolt you can find. Next take the bolt cutter and cut the bolt on the sholder as many times as you can at the same point on the cutter for every cut. This will leave a nasty dent in the cutter and render it useles as a cutter at that point. place a piece of 4 gauge or less wire in the dent and adjust so it just slightly compresses the wire. You are now the proud owner of a 4 gauge or less crimping tool.
You can do the same thing by milling or drilling the cutter, but the cutting a hard bolt is better for people that do not have access to a machine shop. This trick is used by electric car builders for making 24 inch bolt cutters into 0 to 0000 crimpers. If you ever had to crimp that stuff with the "Hammer and anvil" method you would destroy a good bolt cutter to make a crimp tool and not even think twice about it. Besides, a good heavy gauge press style crimp tool would run you $200+ VS $30 for this tool.
Old Sep 11, 2005 | 10:20 AM
  #133
eBasik's Avatar
i used my man power and cut the pieces, as for stripping them, i got i got tin snips and cut around the wire jacket and pulled it off, I havent started the car yet, I just got done doing the install, just came upstairs to see if i wired it correctly, and obviously I did it wrong, would it matter anyway? i did battery to "B" and Body Right, and from "B" point to "A" then "A" to Motor, rather than Motor to Battery, o well it's easy anyway ;)
Old Sep 17, 2005 | 06:33 AM
  #134
Goblin's Avatar
Just wondering if there was a reason only one coil pack was grounded and not all four?
Old Oct 31, 2005 | 05:20 AM
  #135
pinoystarr's Avatar
Originally Posted by mikochu
StackTrayce, sounds good to me. Benefits of the ground kit include better throttle response, less sporatic idle RPMs, clearer audio output, among other things...
tbone587, I don't know if it'd be worth it to have a car shop do it for you. Why not do it yourself? If you're gonna have someone do it for you, you might as well buy a already-made kit from Ground Fusion or whoever...
how much of a difference, does this homemade kits make compared to these other grounding kits with the big disks (that can be found on ebay).
thanks for any help.
Old Oct 31, 2005 | 05:23 AM
  #136
mikochu's Avatar
I think the uber wires are on par with the ebay kits...and with less wires!
Old Oct 31, 2005 | 06:09 AM
  #137
pinoystarr's Avatar
Originally Posted by SXT_HuntToKill
i just did mine took me 1 1/2 hours cause of the phone and eating... i used 6g wire with thick copper... i too had to use a hammer to crimp the connecters... you can do this kit for less than $10 at homedepot... get 10ft of 6g wire (it is the green thick copper stuff) and then go on the other side of that wall and find the conecters i got 4g connecters and 6g connecters... reason for that is instead of using different connecters on each end... i put two wires into bolt B and bolt C... at D the ground terminal i left the wires bare and used the U design of the ground clamp to hold the wires in and at bolt E i used a connecter.... so therefore i used the 4g to put 2 wires into a connecter
from A-B A bolt has 6g connecter and B bolt has 4g
from B-C B bolt has 4g and C bolt has 4g
from C-D C bolt has 4g and D terminal is bare
from D-E D bolt is bare and E bolt has 6g
i only used 4 conneceters saves money lil more time but saves money
anychance... would you have pics of your install?
i kinda like how you did yours but i cant picture it.
Old Oct 31, 2005 | 06:30 AM
  #138
pinoystarr's Avatar
so i've pretty much read through this whole write up and everyone's follow ups. has anyone ran wire grounding all the coild packs??? just interested if it makes anymore difference...
gonna be doing this mod this weekend.
Old Oct 31, 2005 | 03:14 PM
  #139
mykeymagik's Avatar
Anyone sell a grounding wire package.. I've had little luck finding the gauge wire but found everything else.. please help...
Old Oct 31, 2005 | 06:45 PM
  #140
mikochu's Avatar
I've done a one-off kit on a tC that had the coilpacks daisy-chained with ground wires...but the owner did not see a difference. *shrug* The valve cover is made of metal...so I don't think it's an issue.
I did a couple of batches of the uber ground wires in October...sorry you missed out! I won't be making kits until the new year...
