DC Sports 4-1 Header Installation onto xA/xB
Megan Racing header....
First, the gap between the b-pipe and the header is a bit big, but I think I can close it up with the two spring-loaded bolts. BUT the holes in the Megan header are NOT threaded, so I need to go out tomorrow and buy a couple of nuts to hold those bad boys in place. I will edit the post as soon as I get 'em.
Second, as for the donut gasket, how the hell do you get it off the stock header? If I do get it off, do I need to use it with or without the gasket that comes from Megan?
Any help is appreciated since I can't get the nuts until morning anyways.
i do not remember the donut gasket being difficult to remove. the problem is getting it off without damaging it. you could always buy a new one :/
i think that i used a flat head screw driver to get it loose then i worked it off with my hands. the screw driver did damage it slightly, if i recall correctly, but not badly enough to cause any problems (that i am aware of). that was about six months and at least 5k miles ago.
megan gave you a replacement donut? that was nice of them. you should only have one donut on there at a time.
that sucks that there are no threads. the only thing that i can remember about the header-exhaust bolts was the nice rage session i had taking them off. you'll have fun putting them back on if you have to use nuts!
As for the gasket from Megan, it is a regular gasket, not the donut type. I will try to get the old one off then use it, if not I'll try it with just the Megan gasket and see how that works.
Well, off to Home Depot to buy a couple of nuts and then more fun with the xB!!!!
i put my header on July 1st...........last week the shifting felt wierd...and yesterday i had no 2nd, 4th or reverse. upon inspection the DC sport header that got installed melted the shifter cable.......not sure why i would have a problem and ohters have not......needless to say i had to order the cables from the dealer almost a $400 dollar piece.......so beware of my problem ..... wrap the cable or make a bracket.....
$400! EACH?! holy CRAP!
couldn't you get those from salvage?
i have a mmw header which maintains the stock heat shield. it must make a HUGE difference, because i can put my hand down there without feeling much heat after a long drive.
sorry to hear that, man. i know what it is like to lose an investment in car modifications, but not quite that well :/
Originally Posted by jallamas
I noticed were you had you jack stands, can you put the jack stands on the rails. Is that area where you have them that strong? Thanks for the great write up.
Originally Posted by mikochu
There are designated jack points under the car. These are the jack points I used in the tutorial pictures. I wouldn't rest the car on the jackstands via the chassic (two big box beams under the car).
those rails that are behind the jack rail look sturdy, but they do not have that ridge that the jack rail has. i like the ridge because it fits into the groove ofthe jack stands and the jack so they will not slide out of place too easily.
the specified jack rail works well enough that i do not see a point in trying any other place.
i just installed my headers today. took only about an hour. my spring loaded bolts came off fairly easy due to the low milage on my car. also i had no problems with the bolts and nuts. none were damaged. the key factor is start first thing in the morning before you go anywhere and use lots of pb-laster. AND I DID THIS WITH A BROKEN HAND!
hey all, just followed this tech guide, those spring bolts are a ($#($$% to get loose! My dc sport headers are in, problem is, there is whitish smoke that is coming from around the flange area, is this a loose gasket or could this just be the copius amounts of wd-40 that I used burning away from the exhaust pipes? It still smokes after the engine is off so I woudn't think loose gasket, but I wanted to ask the well seasoned scion life crowd for advice. I reused the 2 gaskets that were on there, because Boch toyota parts department qouted my $47 for the donut gasket... that seems REALLLY high, or is this normal for a dealership?
If anyone is a round please let me know, I don't wanna die from Carbon monoxide poisening if I can avoid it ;)
********EDIT/UPDATE********
So the smoke and smell was just the excess wd-40 on the gasket and exhaust pipes. I figured that was what it was because of the white smoke (oil burns white ), it's all ok now. No noticeable difference in sound or power, I have the YDR intake on, but when my exhaust comes this week im sure there will be more hp freed up and the power difference might be notable by the seat of the pants method
It looks good.
A tip though, get yourself a cheater bar, some wd-40 and some wheaties.. those spring bolts are tough motha's to crack, I thought I would be stuck with headers I couldn't put on, but just be persistent and plug away at it and you'll get them!!
It looks good. A tip though, get yourself a cheater bar, some wd-40 and some wheaties.. those spring bolts are tough motha's to crack, I thought I would be stuck with headers I couldn't put on, but just be persistent and plug away at it and you'll get them!!
Originally Posted by Seth_VampyreWar
Well, I did my header just yesterday. Got a new gasket for it, followed your walk through closely. It was fairly simple. Besides tightening those spring loaded bolts back on. *Rubs arm* Blah. But anyway, after starting the car and running it for a while, I noticed that while in gear, my car tends to idle rather low. Low enough to make the car shake. It floats around 600-800 RMPs, or around there. And for a short while, a heard a 'air' type of sound, like when I punched the gas hard, it just sounded like I could hear all the air flowing through the engine. It wasn't really a good sound, trust me. Though that has disappeared already. The only thing that persists is the low idle. Everything else is fine. With the exhaust, intake and headers there is a fairly noticable difference in the mid to high-end power. Plus it just sounds nice. ^_^ Any imput would be great. Thank you.
I had no problem installing mines. Only took 1 hour. The spring bolts came out just as easy. Used no WD-40. When i first started the engine there was white smoke coming the the location of the DC headers. That only last a few seconds.
marchoftheruiner!!! They have socket sets specially made for unscrewing stripped bolts. Good luck finding them!
