electric fan?
Old May 9, 2007 | 06:50 AM
orcas1013's Avatar
Default electric fan?
Ok so I searched for this too. How often should my electric fan be turning on and off? Like when I am sitting say in a drive through with the AC off. I dunno, I am so not used to a toyota that I just want to make sure things are ok with it.
Old May 9, 2007 | 06:56 AM
draxcaliber's Avatar
your electric fan is supposed to come on when the engine is running, but you are not moving, therefore, there is no air going through the radiator, and it isn't cooling the engine. the electric fan turns on to pull air through the radiator to keep engine temps tolerable.
the fan in our box should only turn on and off as you toggle the proper switches for it.
i reccomend you spend some time reading your owners manual.
Old May 9, 2007 | 06:58 AM
Neothin's Avatar
the fan as said above kicks in normally when your at a stop or moving slowly (in stop/go traffic). how often it kicks on and off really depends on the outside temps.
Old May 9, 2007 | 06:59 AM
orcas1013's Avatar
Yeah, my box didnt come with the owners manual. And your box has switches for the fan? Is something you added?
Old May 9, 2007 | 11:02 AM
OldYeller's Avatar
The only "switches" are for the AC fan--the normal HVAC *****. I know you bought used--was it from a dealer? You might want to complain about the owners manual--maybe they will order you one. If not it would be a good investment.
Old May 9, 2007 | 11:30 AM
xBster's Avatar
it's normal for the fan to run when you are sitting still. It is a small, confined engine bay and it needs to keep some cooler air flowing in there. With the A/C it runs almost all the time.
Old May 9, 2007 | 02:52 PM
HMRNBOX's Avatar
OP, I see you live in Arizona, I assume it is pretty warm there. I live in the So. Cal desert myself where it is quite warm and only getting hotter! Anyways, anytime I come to a stop my fan kicks in, so my fan is constantly on and off throughout the day. I wouldn't worry too much, unless you don't hear the fan kick on when you are stopped.
Old May 9, 2007 | 03:12 PM
i mentioned in car switches to talk about the incabin air fan. you know the one that blows through your box's vents. that fan. if those are turning on an off at random, you have a problem! LOL!
but the one for your radiator will come on and off as the ecu sees fit.
Old May 9, 2007 | 11:37 PM
stew32's Avatar
Even when it's not warm and no A/C, it'll cycle constantly if you're not moving. It's a little weird the first time you notice it since the fan seems louder than some others.
You may want to check the rubber "flappers" on the fan shroud to make sure they're ok. They're so air can flow through while you're moving but blocks air from bypassing the radiator when you're stopped and the fan is running.
Old May 10, 2007 | 01:32 AM
orcas1013's Avatar
Sweet! Thanks guys for the new knowledge :0)
Old May 12, 2007 | 08:56 AM
bB2NER's Avatar
Music City Scions
Default Re: electric fan?
As often as it needs to! It does go on and off alot but that's normal.
hondajt
Dec 14, 2015 12:54 PM
neneago
Oct 27, 2015 04:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
excessads
Sep 15, 2015 05:28 PM
Forced4
Aug 25, 2015 08:18 PM
