Few Issues with my zex wet kit
Old May 20, 2007 | 03:54 PM
blacktc06's Avatar
Default Few Issues with my zex wet kit
First problem is
I tapped into the black wire second in from right on tb, thinking this was the tps wire.. its not. Were has everyone else tapped theres?
Second is.. My spark plugs which are ngk iridiums the 11's are pure white even if im not spraying. i went one week with out spraying and i still can not get color on the procelin? I have no mod's expect a axel back and the car runs fine?
i have sprayed a full bottle and not melted any plugs or had any problems yet.
The jets i have currently installed are 32 NOS and 17 Fuel.
Thanks for any help i receive !
Old May 20, 2007 | 04:29 PM
deathbyc4's Avatar
every wire you need is at the ECU so you should be able to hide splices better. got pics of the spark plugs?
Old May 20, 2007 | 04:45 PM
blacktc06's Avatar
I do not have pics. I can take some tommrow.. Do our cars run on the lean side from factory?
Looking through the ecu pin outs now. Thanks.
Old May 20, 2007 | 05:33 PM
blacktc06's Avatar
From the eletrical diagrams i have read, the brown or light green wire off the tb are tps wires?
Old May 21, 2007 | 05:38 AM
Kapthowdy's Avatar
Run a .022 fuel jet for a bottle, then check your plugs again. You should be at a .020 for a .032 nitrous jet, but you bought a universal kit made for all sorts of cars, so it's running a little lean. .022 will make less power, but will be safe.
Old May 21, 2007 | 07:13 AM
blacktc06's Avatar
Thanks for the help guys ill try that and see what it does!
Old May 22, 2007 | 01:36 PM
blacktc06's Avatar
i tried the light green wire with no sucsess!
Any one who has the kit installed have a wire color for me? seems every ecu pin out i see has no tps wire shown!
Old May 23, 2007 | 01:07 AM
fairladyz541's Avatar
Team Sushi
There you go tap the black thin wire on the top of the ecu. Ignore the colors that are written on the diagram those are form installing an AFC2.
Old May 23, 2007 | 07:16 AM
blacktc06's Avatar
thanks a ton! Appreciate all the help!
Old May 23, 2007 | 11:21 AM
vaccaro's Avatar
so what was the rulling black wire?
Old May 23, 2007 | 03:43 PM
Team Sushi
10000000% sure its the small black wire on the top pin.....................
Thats what I have used on my Apexi SAFC2 and my Zex Kit, also I used it on my Nitrous Express Kit...........................
19Geezer38
Jun 1, 2015 12:26 AM
mvez
Scion tC 2G Aero & Exterior
Feb 4, 2015 01:15 AM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
TheTripleC
Jan 4, 2015 06:46 PM
Basebllstar
Dec 17, 2014 07:30 PM
