Few Issues with my zex wet kit
First problem is
I tapped into the black wire second in from right on tb, thinking this was the tps wire.. its not. Were has everyone else tapped theres?
Second is.. My spark plugs which are ngk iridiums the 11's are pure white even if im not spraying. i went one week with out spraying and i still can not get color on the procelin? I have no mod's expect a axel back and the car runs fine?
i have sprayed a full bottle and not melted any plugs or had any problems yet.
The jets i have currently installed are 32 NOS and 17 Fuel.
Thanks for any help i receive !
Run a .022 fuel jet for a bottle, then check your plugs again. You should be at a .020 for a .032 nitrous jet, but you bought a universal kit made for all sorts of cars, so it's running a little lean. .022 will make less power, but will be safe.
10000000% sure its the small black wire on the top pin.....................
Thats what I have used on my Apexi SAFC2 and my Zex Kit, also I used it on my Nitrous Express Kit...........................
TheTripleC
Jan 4, 2015 06:46 PM
Basebllstar
Dec 17, 2014 07:30 PM
