Tranny kind of stiff.
Old Jun 4, 2007 | 07:34 PM
Rasta's Avatar
Default Tranny kind of stiff.
Man just got a clutch and LSD installed on my TC, I have a clutch masters stage 3 clutches and the TRD LSD. The tranny stick is like super stiff it takes the gears but even when the car is off the tranny is stiff. Has this ever happened to any one else here.
Old Jun 4, 2007 | 11:32 PM
toyota_scion_tc's Avatar
What did the install? I would start by checking the shifter linkage to make sure everything is right. Then I would try to bleed the slave cylinder and if this doesn't help look to make sure your oil is at the correct level in your transmission. And after you checked all this I would go back to the place that installed it and tell them its not right.
Old Jun 5, 2007 | 09:26 AM
OuterHeaven's Avatar
I would do the same as above but also try and make sure the clutch is fully disengaging.
Lexparker
Oct 23, 2015 11:39 PM
gyrotech
Scion tC 2G Aero & Exterior
Oct 4, 2015 11:03 PM
goldtoaster
Sep 25, 2015 04:58 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
TheGovernmenT
Sep 4, 2015 11:57 AM
