Tranny kind of stiff.
Man just got a clutch and LSD installed on my TC, I have a clutch masters stage 3 clutches and the TRD LSD. The tranny stick is like super stiff it takes the gears but even when the car is off the tranny is stiff. Has this ever happened to any one else here.
What did the install? I would start by checking the shifter linkage to make sure everything is right. Then I would try to bleed the slave cylinder and if this doesn't help look to make sure your oil is at the correct level in your transmission. And after you checked all this I would go back to the place that installed it and tell them its not right.
gyrotech
Scion tC 2G Aero & Exterior
Oct 4, 2015 11:03 PM
