Hood rattle...
Old Sep 23, 2004 | 05:11 AM
rogcjms's Avatar
NM SCIONS
Default Hood rattle...
hey when im at a stop light my hood sounds like its rattling. has anyone had the same prob. could it be also a low idle? let me know. its bugging the hell outta me!
Old Sep 23, 2004 | 05:28 AM
XBman's Avatar
i havent had that problem, but maybe i can help. Is it only at a stoplight. Like what RPM range is your car in when it does this. My suggestion would be to compleatly identify that it is your hood that is loose. If this is so then get a wrench and tighten the bolts that hold the hood on.
Old Sep 23, 2004 | 05:29 AM
XBman's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=2585
Old Sep 23, 2004 | 07:41 AM
UnFocused's Avatar
- You need to adjust the rubber stops ....
Old Sep 24, 2004 | 03:43 AM
rogcjms's Avatar
NM SCIONS
yeah ir happens when im just at a stop light. im thinking it may be those rubber thingy's or the hood is loose. i was thinking bout taking it to my dealer to have them fix it for free. I'm thinking too its because of a low idle. I know there is a TSB for a low idle.
Old Oct 14, 2004 | 03:09 AM
rogcjms's Avatar
NM SCIONS
Well took my xB to the dealer and they said the engine and hood were normal. they brought in 2 more xB's and put them by mine to match the sound and they said they were all the same. So I guess no real prob for me.
Old Oct 14, 2004 | 03:12 AM
djct_watt's Avatar
Team Sushi
I had a similar problem in my xA. . . were you working on an intake or a battery by any chance?
I made a really stupid error and forgot to put one of the hoses back onto the clamps. Might be worth a check. I put the hose back in and the idle is purr-tastic.
Old Oct 15, 2004 | 03:49 AM
rogcjms's Avatar
NM SCIONS
nope havent touched my engine except just cleaning little spots. but not enough to make it do something like that. They said its normal so i aint even gonna worry about it.
Old Oct 19, 2004 | 05:44 PM
CBSIMONSEZ's Avatar
Twist those rubber bump stops under the hood all the way up. Close the hood, and see how it looks. If the hood sites too high, then lower each evenly till it looks right. Your rattle should go away then. I had the same problem long ago, adjusted the bumpers, and now .... silence.
yupinmytC
22
Jul 27, 2024 07:08 PM
mikeac
Sep 15, 2015 03:24 PM
Btp907
Sep 15, 2015 02:54 AM
mc1114
Scion tC 1G Aero & Exterior
Aug 10, 2015 10:34 AM
