headlamp bulbs
Old Jul 2, 2007 | 11:39 PM
cincinfocal's Avatar
Default headlamp bulbs
i have not recieved mine yet so i cant check the manual and search yielded nothin...but what kind of bulbs are we running in there? for hi's and lo's...
thanks
Old Jul 2, 2007 | 11:51 PM
2slow4u's Avatar
my manual says 97004??????????
Old Jul 3, 2007 | 01:24 AM
Linx's Avatar
And I believe that is the same as a H11 (low beams). I forget what the hi beam bulb is
Old Jul 3, 2007 | 03:29 AM
postman's Avatar
Default Bulbs
Wonder if we can use the SilverStar Ultra in the XB?
Old Jul 3, 2007 | 04:47 AM
roXor_boXor's Avatar
Default Re: Bulbs
Take a look at this thread over at PriusChat. I read there a lot because of my wife's car.http://priuschat.com/index.php?showt...&hl=SilverStar
Be sure to read all the way through.
Seriously look at the 6000k or 4300k Mobile HID kits if you want white brighter/ better lighting.
Old Jul 3, 2007 | 01:33 PM
2008Xb's Avatar
The stock low beam is bright already. Put anything brighter it will be hard on the etes of passing traffic.
postman's Avatar
Default SS
Had SilverStars in my Rav4 for 4years....Never had a problem.......They give about 20% more light......Heard they may burn-out faster...
Old Jul 3, 2007 | 03:30 PM
uberspeed's Avatar
With a proper projector housing, like the xB has, and a rather marked cutoff, why not go to HID's? The lumens output from halogen to HID isn't even a fair fight (proper HID 4100-6000K at most, 4100-4300 is your best bet for visible light). Drive a car with HID's, you'll feel blind when going to halogens. I do agree with you on cars that have regular housings, the scatter and glare pattern is bad, add HID and it's worse; those are, in my opinion, also a safety issue for oncoming drivers.
Old Jul 3, 2007 | 04:45 PM
h11 is 90005...and i am not able to find anything in 97004 for cars...shows up as a small halogen bulb to usin in desk lamps...
Old Jul 3, 2007 | 05:55 PM
xhrhx15x's Avatar
i upgraded to HID's. (MobileHID.com or PM Cliffud)
The bulb numbers are 4 digits, not 5. Lowbeam headlights for the '08 xB are 9005 or H11.
i have all the bulb numbers for the '08 xB so if you need to know, PM me and i will be more than happy to help out.
Old Jul 4, 2007 | 08:02 AM
Linx's Avatar
Hey xhrhx15x, I just upgraded to HID's myself. Did you find it to be a problem to get the bulbs to fit? I did. The base of the bulb was a hair bigger then the hole in the housing. I had to use a dremmel tool to make the hole a little bigger. I dealt with this same problem on my last car. I bought aftermarket projectors for it and found that the hole was a tiny bit too small for the bulb. But my XB looks so much better with the HID set up
Old Jul 4, 2007 | 05:34 PM
xhrhx15x's Avatar
i didn't have any problems with the bulb fit. i love the way it looks with the HID's. now i have to upgrade my fogs & brights. i am also doing a whole LED conversion for all the bulbs.
Old Jul 5, 2007 | 07:55 AM
Linx's Avatar
You're gonna put HID's in your brights? Wow. Tonight (July 4th) was the first night I drove around with my HID's on. I got a few people flashing me cuz I guess I am shining pretty bright. Putting HID's in your brights, you're really gonna blind people. I wanna get some fogs but I guess I'll go with some aftermarkets. I'll probably add HID's on those
Old Jul 5, 2007 | 03:57 PM
uberspeed's Avatar
HID's on the high beam? Correct me if I'm wrong but don't HID's need some time to "warm up"? Being that high's are usually used to flash is that a good application? I believe that would also be quite blinding to on comers no?
Old Jul 5, 2007 | 04:47 PM
xhrhx15x's Avatar
Oops. i just read what i wrote. I didn't mean that I was gonna upgrade the high beams to HID. I'm prolly gonna get some silverstars for the fogs and the high beams.
hondajt
Dec 14, 2015 12:54 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Subaru86
Sep 14, 2015 12:43 PM
SJMiller
Sep 12, 2015 06:33 PM
