Blown HID bulb or blown ballast?
Recently my passenger side headlight has started to fail. I have 6000k HIDs in them for about 8-10 months now. When they first started to fail, it would turn on but be very faint, then after it has "warmed up", which takes a few minutes, it has its normal light output, but also slightly brighter than my driver's side. But now, it just flickers once when I turn my headlights on, but just dies afterwards, no faint lighting or anything, just off. Because of the initial flicker, I'm unsure if the problem lies within the bulb or is it the ballast or even possibly both? I would also like to know how I would go about replacing whichever part if necessary--does it matter if they are different brands and so forth. Thanks for reading and thanks in advance for any help.
i have not swapped the bulbs yet.. the manufacturer wont return any of my e-mails, and the company who sold them to me says i have to go through the manufacturer. do u mean swap driver side bulb with passenger and see if it continues, or swap for a new set of bulbs? im going to try and switch them tonight to see what happens... if it continues with that bulb, then its clearly the bulb.. if it continues to do it on that side with the different bulb, what could it be?
Swap the good bulb into the non working side to see if it's a bad bulb, if it is then the good bulb should light up. if it still doenst light up, it's probably the ballast. So you could put the bad bulb on the good side at the same to to test to see if the ballast is bad. Do you know what i mean?
ok i swapped the bulbs today and ill take a drive tonight to see if it does it... i guess we will know soon enough! thanks for your help guys... the egg is clear on both sides, i think, it lights up... just flickers occasionally, so its weird, i dont know.
Originally Posted by kiss_tc
as odd as it is, i swapped the bulbs to the other side from the original, and they work jsut fine? can anyone explain this?
ok, i lied.. still does it.l same thing from that bulb on the other side. i havent really had a chance to drive it at night much until last night, and yup... its bad. and the manufacturer wont contact me back, and the seller says i have to go to the manufacturer. not happy!
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
SJMiller
Sep 12, 2015 06:33 PM
