Crazy door locks
Old Sep 8, 2007 | 05:44 PM
joemamasmurf's Avatar
Default Crazy door locks
OK, so one day I noticed my drvers door door lock is not locking or unlocking with the remoe or electric door locks. It's only the drivers door doing it and the door works fine with the key. I can see the lock move just a little when I try to unlock the doors but it doesn't unlock. Any ideas?
Old Sep 8, 2007 | 05:51 PM
dmpsk8's Avatar
pull the door panel and check to make sure everthing is moving correctly. might just be hung up on somthin
Old Sep 8, 2007 | 06:05 PM
tcday's Avatar
1 how long have u had the car 2 u might need a new motor for the locks cuz i had the same trouble in my old car so i took it to the dealer and dey said da motor bout do die out so just check dat out
Old Sep 8, 2007 | 08:44 PM
Ok, my car is an '05 and I bought it new, so its only like 2 years old. I took the plastic part off of the door and it didnt look like anything was hung up.
Old Sep 8, 2007 | 08:58 PM
dmpsk8's Avatar
Not sure. it could be the motor, but i dont see that goin bad this quick
Old Sep 8, 2007 | 09:20 PM
xbsilvee's Avatar
I noticed when I use the key to unlock the passenger door, All the doors unlock/lock. But, when I unlock the driver's door, all of the other 3 doors remained locked. Hmmm
Never looked at that till yesterday. Anyone else?
Old Sep 8, 2007 | 09:57 PM
travisweb's Avatar
I think you need to get a new "door lock actuator". I had the same problem in my truck....new actuators fixed the problem....cheap fix too.
Old Sep 9, 2007 | 12:35 AM
swartzautoman's Avatar
my drivers do is starting to have this problem.
the other day i had the window down and my arm loked the door. when i got to were i was going i tried to get out... nothing, i couldnt even pull up on the door lock. i tried to lock it then unlock it with the remote, nothing. i tried using the button in the door to lock and then unlock it, still nothing.
man i was hot, everyone was stairing at me tring to get out of my car.
i had to reach outside and use that door handle to get out and it worked fine.
i havent had that problem since.
ill just take it over to the dealer it it gets worse.
the thing that made me so mad was a group of people (that i know) waching me try and get out of my car.
Old Sep 9, 2007 | 04:35 AM
OldYeller's Avatar
My RS2 is doing the same thing. I attributed the problem to my Boo boos---but maybe there is another problem.
Old Sep 9, 2007 | 06:50 AM
jwaj2002's Avatar
TOCC
mine does it when its cold, just about broke the key off in the door lock last year, spent last winter crawling through the backseat to get in, and the dealership wouldn't fix it, said they couldn't duplicate the problem
Old Sep 9, 2007 | 10:44 AM
bB2NER's Avatar
Music City Scions
Hope it's something simple.
Old Sep 9, 2007 | 11:02 AM
bgtfc's Avatar
When you unlock the driver's door, if you turn the key again, the others will unlock.
Old Sep 9, 2007 | 08:36 PM
z's Avatar
z
That is normal. When you unlock the drivers door,, one twist of the key will only unlock the driver's door. Twist the key (the same way) a second time and it will unlock all other doors. When unlocking from the passenger side,, it will unlock all doors with one twist. This - I believe - is sort of a safety thing so when you unlock your door to get in,, someone could be crouched on the other side of the car and jump in with you.. i.e. a car jacker of sorts. But anyway,, not sure if anyone else told you that,, and I didn't want to read all the posts....
Old Sep 10, 2007 | 12:01 AM
bB2NER's Avatar
Music City Scions
I don't use my key cause I have covers over the lock holes.
Old Sep 15, 2007 | 03:27 PM
xbsilvee's Avatar
Thanx I'll try it
Old Sep 15, 2007 | 03:29 PM
xbsilvee's Avatar
Thanx
Old Sep 15, 2007 | 07:17 PM
Crispyxb's Avatar
I am having the same problem with my drivers rear door. The lock whats to lock or unlock, just doesnt seem to have the juice. I will see if something is hung up.
Old Sep 15, 2007 | 07:31 PM
tommygunn's Avatar
I had the same problem about a month ago. I took my RS2 to the dealership and it was a weak actuator. They replaced it for free because it was under warranty. It works fine now.
Old Nov 22, 2007 | 05:48 PM
jrockitcoolcat's Avatar
I've had the same problem for about a year now. I finally peeled the door off and I think it may be a crappy actuator, or bad wiring. Problem is, they don't sell actuators like this at AutoZone.
I brought the issue up under warranty last year with my dealer before the warranty ran out, so I'm going to give it back to them to fix - it works without fail now, and it isn't unduplicateable.
This guy's quote is freakin hilarious:
He obviously doesn't have his key fobs, or hasn't ever driven his Scion new... lmao
Old Nov 23, 2007 | 03:15 PM
NewMexicoxBPhatBoy's Avatar
Yes, this has happened to me MANY TIMES!! very embarrassing actually it is exactly the story that swartzautoman told......Its like if i have it locked, and pull the door **** before i unlock it, and THAN try to unlock it, it wont come up, ive gotten locked into my OWN CAR for about 10 minutes because this happened...it happens to all my 4 doors, i always tell people in my car, DONT PULL THE LATCH IF ITS LOCKED, WAIT TILL I UNLOCK IT AND THAN PULL LATCH lol.. they look @ me weird, but its gonna save US the embarrassment
DaBlackBox
134
Apr 10, 2022 02:04 PM
mischadoll
Mar 9, 2015 05:48 AM
toyotaisme
Jan 10, 2015 10:24 PM
lunchbx05
Dec 29, 2014 07:53 PM
Orataro
Jan 31, 2004 11:56 PM
