so lotsa stuff to discuss ive been away for awhile
Old Sep 10, 2007 | 08:17 AM
george_da_2nd's Avatar
Default so lotsa stuff to discuss ive been away for awhile
so ive not had internet do to moving and comcast sucking alot of d!ck. so i have some stuff im working on. first of how do i turn off my mainence required light off. secondly. has anyone put in last gen celica seats in a tC ive searched but no real ansures as to whats needed. brackets modifycations and so on.... pics would be great! man its great to be back on.
Old Sep 10, 2007 | 10:03 AM
JOEinSD's Avatar
I guess you were gone when they added the new "Search" feature on the site. It's the red button up there. ^.
Old Sep 10, 2007 | 11:31 AM
AKAvensis's Avatar
would have taken you the same effort to answer the question that it did to type that to him.
Old Sep 10, 2007 | 04:30 PM
im asuming you dident read the part where it said i searched
Old Sep 10, 2007 | 05:43 PM
Luc1f3r's Avatar
you may have searched, but you cant spell, and that is the problem...
7. how do i reset and/or specify the interval for the 'maintenance required'/oil change light using the trip meter button?
the tC's ecu (computer) memorizes the distance your car has traveled. scion recommends that you change your oil every 5,000 miles. when your car exceeds 4,500 miles, the ecu will flash the maintenance required light for 12 seconds after turning the key to 'on'. if it exceeds 5,000 miles, then the ecu keeps the maintenance required light on until it is reset. so, how do you reset it? follow these steps:
step 1 turn the key to the 'on' position. using the trip meter button, toggle the lcd until 'ODO' is displayed.
step 2 turn the key off. now, push and hold the trip meter button. while holding the trip meter button, turn the key to 'on'.
step 3 while you continue to hold the trip meter button, you will see on the lcd disply five (5) small dashes and they will begin to 'count down' rather quickly.
step 4 continue holding the trip meter button and once all the dashes have been cleared, your lcd will display six zeros (000000) - release the trip meter button now - and then the lcd will display 'ODO' and your current mileage. at this time, your 'maintenance required'/oil change light has been reset.
*note* each dash represents 1,000 miles. if you like to change your oil every 3,000 miles for example, release the trip meter button when only two (2) dashes remain. that way, you will get the reminder light at the next 3,000 mile mark instead of 5,000.
8. how do i clear the 'maintenance required'/oil change light using the trip meter button?
if at the time you changed your oil, you or the person changing your oil did not reset the 'maintanence reqiured'/oil change light or if you would just rather turn it off instead of setting the interval (aka- the lazy way to turn off that annoying light), follow these steps:
step 2 reset both trip meters to zero. you can reset the trip meters to zero by selecting trip a or trip b and holding in the trip meter button for five (5) seconds.
step 3 after both trip meters are reset, select any trip meter and hold in the trip meter button and start the car.
step 4 continue holding the trip meter button until the "maintenance required' light disappears.
Old Sep 10, 2007 | 05:52 PM
JOEinSD's Avatar
Took me a whopping minute to come up with these.
https://www.scionlife.com/forums/viewtopic.php?t=20749
https://www.scionlife.com/forums/vie...ight=maint+req
Maintenance light RESET:
Page. 96 of Scion tC 2006 Owners Manual
1. Turn the ignition key to the "OFF" position with the odometer reading shown.
2. Turn the ignition key to the "ON" position while holding down the trip meter reset ****.
Hold down the **** for at least 5 sec. the odometer inidicates "000000" and the light goes off.
Old Sep 10, 2007 | 07:28 PM
cool so what about the celica seats?
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
jdmautoimports
Regional - Canada
Sep 24, 2015 04:00 AM
BlingSlade
Sep 5, 2015 08:52 AM
pjl52
Aug 13, 2015 02:38 PM
bmxScion
Jul 23, 2015 12:07 AM
