Spare Tire Box build Problem ....
Old Sep 13, 2007 | 03:38 AM
markritch's Avatar
Default Spare Tire Box build Problem ....
im planning on mounting 1 12'' sub in the spare tire well ...my problem is, the tire well is not centered at all on the base of the trunk ...can anyone help me that has done a 12'' install in the spare tire well. What ways around it are there....i was planning on building the frame out of MDF but it wont be centered ...any input will help, pics too if you got them ...thanks guys
Old Sep 13, 2007 | 04:09 AM
rocketgyrl's Avatar
You can offset the cutout for the subwoofer, and then make a trim piece for the floor of the hatch. Or you could do what I did, and make the fiberglass floor off center:
Old Sep 13, 2007 | 02:16 PM
markritch's Avatar
yea i was thinking about off centering the box ...but that would be WAY too big cause its only one 12'' ...i can almost lay the frame of the box inside the tire hole but its inpossible to offset the cutout
Old Sep 13, 2007 | 03:01 PM
mandos's Avatar
It's too far to the side to make the cut out in the center?
I played with it long ago, when my hatch resembled stock and I thought you could offset it enough.
Time to take apart Courtney's car again ;)
Old Sep 13, 2007 | 03:14 PM
markritch's Avatar
yea my prob is the outer frame doesnt quite fit in the hole it needs to go up on one of the edges ...but too small to be on both edges of the hole ...this is kinda what my box will look like ....will the shape of the right side effect the building u think ?
Keeshwah's Avatar
How did you glass the floor?
Old Sep 13, 2007 | 03:24 PM
rocketgyrl's Avatar
We first applied damping materials to the trunk's floor. The box was a simple frame - as shown in the top pic. The black color is fleece that was stapled to the perimeter of the MDF. You can use 3M90 spray glue to stretch and stick it to the contours of the floor, then apply LOTS of resin and fiberglass mat (yellowish color).
Old Sep 13, 2007 | 03:25 PM
Keeshwah's Avatar
Did you glass right to the floor? Not to painters tape or something to make it removable?
Old Sep 13, 2007 | 03:33 PM
rocketgyrl's Avatar
The top of the *dynamat* is non-stick foil, and thus the box didn't stick to it. You can use tape or whatever you want in areas that aren't covered in dynamat, but these areas don't exist in my trunk!
CombatmedicR56
Nov 12, 2020 01:53 AM
Marvelicious
May 1, 2015 08:00 PM
evolving_machine
Jan 13, 2015 08:04 PM
STCxB
11
Jan 9, 2015 04:30 PM
Godfryness
Jan 2, 2015 11:18 PM
