HID Problem help please
Old Sep 27, 2007 | 01:15 PM
elite-fusion's Avatar
Default HID Problem help please
for some apparent reason when i turn my headlights on, sometimes only one turns on and the other one doesnt, so what i have to do is turn the headlights off and than back on around 1 or 2 times and than both turn on, can someone please tell me why this is happaning? and how i can fix it?
please someone lol its irritating lol
Old Sep 27, 2007 | 01:57 PM
dugzilla's Avatar
could be a few different things. are you running power to your hid's through a relay or through the stock bulb harness?
You could have a bad connection.
you could have a ballast going out.
If you are not running a relay you probably are not getting enough power through the stock harness to power the ballast to ignite the bulb.
Old Sep 27, 2007 | 02:05 PM
can someone please tell me how make the connection through a relay i never did anything like that, because it started occuring a few days ago but before it worked fine, i have both hids in headlights n foglights, so please teaxh me how run stuff through its own relay
Old Sep 27, 2007 | 02:13 PM
dugzilla's Avatar
So you are not running a wiring harness with a relay, correct?
The easiest thing you can do is PM cliffud in sponsored sales about ordering 2 harness for your hid's, they are all wired up and ready to go.
I think they are only $20 each and really easy to install. It's a lot easier than trying to explain to you how to wire a relay, lol.
Old Mar 29, 2008 | 06:30 AM
Tom11x's Avatar
Default HID Help please
Hey i just recently have this problem. my right side is not turning on no more. before i would hear a beeeepp noise thru my back speakers for about a month now and now it wont turn on. My kit is plug and play. what should i do?
i switch the right to left. the same one still doesnt work.
not the fuse or the bulb
6000k
Old Mar 29, 2008 | 07:31 AM
chubbykai's Avatar
I have the same problem with my HIDs in my VRD fogs. I was thinking about the relay the other day... itll prolly solve my problems..
Old Mar 29, 2008 | 10:41 AM
Wingman172's Avatar
most of the time if its the one side that doesnt turn on, its the ballast. Try the non-working bulb on the working side and if it turns on then its definitely the ballast. If they both dont work check out the fuses and relay.
I would really look into getting a relay asap, you will burn out the stock harness pretty quickly.
Old Apr 1, 2008 | 04:35 AM
ScionFreak08's Avatar
yea i had the same problem i just switched the ballast from sides and it still did it the first day after that they worked again no problem at all...
Old Apr 1, 2008 | 05:25 AM
Tom11x's Avatar
same thing as mines before. Now it won't turn on anymore. I found out that one of my ballast didn't work so I order a replacement at mobilehid.com and also order the relay harness because mine was a plug n play. Getting it all in about a week
Old Apr 17, 2008 | 12:31 PM
cliffud's Avatar
I'm a little late to this thread but I thought I'd chime in to show you a picture of the relay harness. Believe me, it's a lot easier to just pick one up vs making one yourself. I tried.
Wire harnesses are $20 shipped.
Just order them here: http://www.mobilehid.com/scionlife.htm
Thanks!
Clifford
Old Apr 17, 2008 | 10:01 PM
chubbykai's Avatar
great product, and VERY easy to install. Just finished installing mine last week and it works like a charm.
Wolfgang94
Mar 24, 2015 12:48 PM
S7ephavs
Mar 22, 2015 12:09 PM
GoodVibes
Mar 10, 2015 04:29 AM
mvez
Scion tC 2G Aero & Exterior
Feb 4, 2015 01:15 AM
tc_Jake
Dec 31, 2014 01:45 AM
