rear wheel drive
Old Nov 15, 2007 | 03:42 AM
koteman's Avatar
Default rear wheel drive
is there any way o make a tc rear wheel drive if so how hard would it be and how much and where would i get the stuff
Old Nov 15, 2007 | 03:43 AM
2_much_tc's Avatar
are you serious?
Old Nov 15, 2007 | 03:45 AM
Mugetsu's Avatar
buy FORZA 2 for your 360...BAM! RWD TC
Old Nov 15, 2007 | 03:49 AM
BlizZard's Avatar
Old Nov 15, 2007 | 03:52 AM
Aroddalobster's Avatar
i think there have been a couple threads on this, and the final decision was that its a total waste of money. better off spending your money on a car that's rwd from the factory.
Old Nov 15, 2007 | 03:56 AM
Complication's Avatar
um need I be the one to say it...
SEARCH..
but to answer your question just like everyone will very soon, anything can be done with enough money. there are rumors of one in the Cali area...
There will be a ton of work like creating a path for the drive shaft, cutting the firewall (big no no), moving the fuel tank. in the end you may end up with RWD tC but not a daily driver.
if you have the money, good luck, I mean I'll put it this way, around where I live we've got a 96 civic with a LS7 corvette motor... he does drift events and such... it was a ton of money for a car that currently looks like crap.. but it's a Beast... if you want it bad enough it will happen... you'll just have to throw a ton of cash at someone to do it. hell.. for tell you what...
for 45K I'll do it...
Old Nov 16, 2007 | 07:29 PM
malibuboy54's Avatar
learn to drive, like track, and be able to feel your car.....rwd is tricky to master cause there's lot of potential to slide out if you don't understand what's going on, etc....i'm still trying to push the z to the limits on the track and everytime i learn something new! lol
Old Nov 16, 2007 | 07:32 PM
Enrique9876's Avatar
Originally Posted by 2_much_tc
are you serious?
hahaha thats the best reaction ever.
Old Nov 17, 2007 | 06:07 PM
goaliesmk's Avatar
obviously you have never worked on a car before and know nothing about them. my advice is go to school and answer your own question about making your tc rwd
Old Nov 18, 2007 | 04:02 AM
koteman's Avatar
i wish i could but my stupid school has nothing like auto shop or even wood shop
Old Nov 18, 2007 | 05:17 AM
captainlaziness's Avatar
Drive in reverse all of the time?
Old Nov 18, 2007 | 05:31 AM
2fast4you's Avatar
Team ScionTific
Default Re: rear wheel drive
All it takes is money!
Old Nov 18, 2007 | 06:05 AM
too bad that doesn't even use the Scion motor.
Old Nov 18, 2007 | 06:09 AM
smilezdc's Avatar
ahahahahahahhahahaha
Old Nov 18, 2007 | 06:23 AM
2fast4you's Avatar
Team ScionTific
It still uses a Toyota motor, but if your going to spend thousands of dollars doing a RWD conversion, why would you waste your time with a 2AZ? :?
Old Nov 18, 2007 | 07:03 AM
Prophecy2k4's Avatar
Sometimes people want to do things just to do them.Me and chicagosfinest wanted to be the first people to put a v6 in a tc.Sure we could have spent the money on just building the 2az or even put in a 4 banger with "better potential",but that wasn't the point.We wanted to be the first,and thats why we did it.
Yes you can make a tc rwd,and yes it will be more then an in-and-out job.It will take you a few thousand dollars and alot of research,but with the know how it can be done.
It saddens me to see the amount of discouragement on this and many other forums.If everyone used the logic that "it's not worth it",nothing new would ever get done.We've established that it will be expensive and time consuming,but that doesn't change the fact that it is doable.
Old Nov 18, 2007 | 09:57 PM
goaliesmk's Avatar
So where are the pics of this v6 tc?
Old Nov 18, 2007 | 10:03 PM
search ''v6 tc''.
Old Nov 18, 2007 | 10:07 PM
Mugetsu's Avatar
I agree with you(now a few months back i thought the idea was laughable) BUT the point is that most people are thinking that its a mod around the complexity of a "motor swap" but its not its like that X 10 in modification. and the car "literally becomes some thing else" for example that pic posted by 2fast4you...
thats a tubular frame dragcar with the exterior body panels of a TC if i'm right it has a 2JZ swap wich means the driver is sitting next to a transmission, there is porbably nothing left of the rear end or the entire drivetrain or suspension...
I don't think people are trying to down the fact or discourage thinking out side the box, just being realistic towards a car that is in essence STILL a TC not just in aesthetics.
kleecker
9
Aug 2, 2022 05:00 AM
Joeynenj
Nov 25, 2014 05:29 AM
Slopoke21m
54
Apr 23, 2007 12:25 AM
scionara
38
Feb 25, 2004 04:52 AM
Kodokan_4
Oct 29, 2003 05:49 AM
