08 xb remote start/alarm wiring diagram
Does anyone have it? Ive done many tC's, but didnt know the locations and wire colors if they were the same. Any help would be appreciated
12 Volts white (30A) + ignition harness
Second 12 Volts yellow (7.5A) + ignition harness
Starter white + ignition harness
Second Starter white + ignition harness
Ignition gray + ignition harness
Second Ignition white + ignition harness
Accessory black + ignition harness
Key Sense blue -fuse box, R side, 32 pin plug, pin 23
Power Lock lt. blue -driver kick, 18 pin plug, pin 7
Power Unlock pink (double pulse) -driver kick, 18 pin plug, pin 6
Lock Motor orange 5 wire driver kick, 18 pin plug, pin 8
Unlock Motor lt. green 5 wire driver kick, 18 pin plug, pin 17
Disarm Defeat lt. blue 5 wire fuse box, middle, 18 pin plug, pin 18
Parking Lights (+) green + fuse box, top L, 30 pin plug, pin 29
Parking Lights (-) white -headlight switch
Hazards gray -hazard switch
Headlight black -headlight switch
Reverse Light red + fuse box, top L, 30 pin plug, pin 30
Left Front Door Trigger white -driver kick or fuse box, top L, 30 pin plug, pin 21
Right Front Door Trigger brown -pass kick or fuse box, R side, 32 pin plug, pin 20
Left Rear Door Trigger lt. blue -driver kick, 13 pin plug, pin 10
Right Rear Door Trigger lt. green -pass kick or fuse box, R side, 32 pin plug, pin19
Dome Supervision white -fuse box, L side, 6 pin plug, pin 2
Trunk/Hatch Pin lt. green -fuse box, top L, 30 pin plug, pin 7
Trunk Hatch/Release orange -driver kick, 13 pin plug, pin 3
Trunk Release Motor red 5 wire driver kick, 13 pin plug, pin 2
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer gray ac data link connector, pin 9
Rear Defroster black - latched HVAC controls
Speed Sense purple ac radio harness
Brake Wire blue + fuse box, top L, 30 pin plug, pin 9
Parking Brake black -fuse box, top R, 16 pin plug, pin 5
Horn Trigger lt. green -fuse box, top, 36 pin plug, pin 28
Left Front Window (Up/Down) pink - white A driver window switch in door
Right Front Window (Up/Down) green - brown A driver kick, blue 12 pin plug, pins11,6
Left Rear Window (Up/Down) red - blue A driver kick, blue 12 pin plug, pins 8, 3
Right Rear Window (Up/Down) green - brown A driver kick, blue 12 pin plug, pins 7, 12
The easiest way to do that would be to find the fuel pump fuse at the fuse box under the hood. It should be in your owner's manual. Remove the fuse and solder some wires to it. Be sure to use an external fuse holder once you install your kill switch. Fuses are your friend
2008 xb, does anyone know which black wire on the headlight switch is for the headlights, there are 2 black wires and they both short to ground when I turn the switch to headlights. I know i could cut them to find out but I don't want to do that. I'm guessing it should only be one wire and not one for each headlight. Man we need to get a 2008 manual on here. Please help if you can.
headlights are -black, white pin, pin 20... thats what my wiring guide says it doesnt have a picture hope that helps. its a negative trigger, you should be able to just use a test light and probe it
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
stillcole
Scion tC 2G ICE & Interior
Apr 6, 2015 03:42 PM
TheSilencerTC
Feb 24, 2015 04:56 PM
