Line output for amp powering 6.5 components
Old Jan 26, 2008 | 04:41 AM
Travis71902's Avatar
Default Line output for amp powering 6.5 components
How would I wire this up guys?
Thanks,
Travis
Old Jan 26, 2008 | 08:04 AM
combatsteve's Avatar
connect the line out converter to the front speakers coming from the head unit, then you can either run wires directly to the speakers in the doors or run them back to the back of the head unit cut the front speaker wires after your connections to the line out and connect your speaker wires from the amp to the factory speaker wires going to the doors.
Old Jan 26, 2008 | 10:32 PM
My components aren't working...What did I do wrong guys!?
Old Jan 27, 2008 | 12:29 AM
Somebody has to know? I'm freaking out
Old Jan 27, 2008 | 12:40 AM
captain_co's Avatar
first of all why in the hell would you use a line out converter to get your rca input... the sound is going to be terrible. go out a buy a head unit for a hundred bucks or so and it will have pre-amp outputs
second - check the settings on the amp... if you have the gain turned all the way down then there will be no power output from the amp
third - grab a multimeter and check the signal from the rca cables to the amp... if there is no voltage running through the rca cables then there is no signal running to the amp for it to amplify
fourth - use the mulimeter again to check the voltage of the speaker wire from the amp and see if the amp is even producing any power
Old Jan 27, 2008 | 01:15 AM
I got it. LOC was turned all the way down.
Old Jan 27, 2008 | 01:17 AM
Bad thing is my $200 CDT's don't sound as near good as the factory speakers did. That was a nice waste of money and time
Old Jan 27, 2008 | 01:26 AM
Not trying to be a dick but you don't know what you are talking about. First off line out converters aren't all that bad. The common person probably wouldn't even notice. Second even with the gain all the way down on the amp there will still be output. The gain is not a volume control it is the input sensitivity that is supposed to be matched to the output voltage from the source unit.
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
missing_image
Feb 7, 2015 07:18 PM
corbmonster
Jan 24, 2015 06:13 PM
Erickdimas7
Jan 16, 2015 03:41 AM
cwong1001
Dec 3, 2014 03:30 AM
