To Bass Boost, or Not to Bass Boost
Old Jan 29, 2008 | 03:43 PM
SePaTc's Avatar
Default To Bass Boost, or Not to Bass Boost
pretty straightforward, do you use the bass boost circuitry in your amp or not? (i'm not asking for info on bass boost, i'm taking a poll to see if other people feel the same way i do about it)
Old Jan 29, 2008 | 03:44 PM
trialsindude's Avatar
Strictly Scionized
noob
Old Jan 29, 2008 | 03:49 PM
CRUZtc8's Avatar
Bass boosty!!!! :D
Old Jan 29, 2008 | 04:48 PM
Blacklistcustomz's Avatar
I don't use it on my subs because they get all distorted when i use it. Although i never tuned the amp correctly and the wiring is all messed up so don't take my word for it.
When JL audio's new subs come out i am going to buy them.
Old Jan 29, 2008 | 04:57 PM
SePaTc's Avatar
Originally Posted by Blacklist
customz
better start saving $$$ now...
well, if your amps not tuned right and have bad wiring, i'd say you'd want to get that taken care of.
let me explain better: i listen to a wide variety of music (ranging from bob dylan and the dead, to nirvana and greenday, sublime and pearl jam, the roots, outkast wu tang TCQ, Rage, bob marley, zeppelin and floyd...basically everything but country and hardcore). as my amp/subs are tuned now (no bass boost), the hip hop/sublime bass notes play hard and loud, while the rock songs are lacking in good bass.
however, if i turn the bass boost on and up, i get rich deep bass on the rock songs, but way overpowering, boomy and distorted bass on the hip hop type songs.
different types of music record bass notes at different levels (obviously hip hop bass notes are at a higher level than rock ones).
Unfortuately, the remote bass boost control didn't work on my amp, otherwise i could just adjust it at my seat, but i'm contemplating retuning the amp with the bass boost set to like 4-8 db's, so i get the bass on rock songs, but then i can turn down the subwoofer level on the HU for rap songs.
Old Jan 29, 2008 | 05:04 PM
nebster's Avatar
bass boost is not a volume ****.
typically the bass boost on any amp distorts the signal and ends up clipping the sub. once againg
bass boost is not a volume **** don't treat it as such
Old Jan 29, 2008 | 08:01 PM
D1G1T4L's Avatar
Originally Posted by SePaTc
if i had any questions for these kids, I would ask them. Frankly, there isn't much that a 19 or 22 year old kid knows that someone whose been in the business/import scene for 8 years doesnt' know....
I ANSWER questions.
Anyways, I have bass boost totally off, if I need more subbage I turn the sub level up at the HU.
A lot of rap is meant to have really heavy bass. If it sounds bad on your system, maybe your system needs some help.
For certain songs that have REALLY weak bass (like the Cars Greatest Hits... what a wimpy mix...), I will turn on the bass boast in the iTunes EQ so that my iPod bumps up the bass for me, so don't have to worry about it.
Old Jan 29, 2008 | 08:04 PM
nebster's Avatar
yeah high_contrast makes a good point. i thought u were an installer for 8 years... shouldn't you know wtf bass boost is??!?! oh wait you just run audiobahn
Old Jan 29, 2008 | 08:12 PM
GQQSE13's Avatar
BOOST!!!!! (if not then my amp shuts off from trying to run too much power )
Old Jan 29, 2008 | 08:18 PM
TheQuietThings's Avatar
bass boost is off
if you need louder bass turn up the gain on the amp, or adjust HU settings.
Old Jan 29, 2008 | 08:33 PM
tCeeJay's Avatar
Elemental Designs had a good video on why you shouldn't use bass boost but its no longer on their site. Anyways, from personal experience, using the bass boost always gave me a distorted signal to my subs especially at high volumes.
Old Jan 29, 2008 | 08:35 PM
nebster's Avatar
Originally Posted by TheQuietThings
bass boost is off
you want to be really careful treating your gain as a volume ****. there should be one volume **** and that should be on the headunit, everything else should remain the same
Old Jan 29, 2008 | 08:42 PM
bass boost is off
I know and you are 100% right. I have my gain set around 70% with the bass boost totally off, and the HU with the bass settings off. If i need more bass, i add it from the headunit.
But for someone who has their gain set on say... 40% and wants a punchier sound and already has the HU settings with a lot of bass, then the gain **** should be adjusted before the boost settings
Old Jan 29, 2008 | 08:49 PM
vettereddie's Avatar
Never use bass boost. I tuned my amp (JL 500/1) using a downloaded 50 Hz 0 dB gain tone, head unit settings set to 0, volume at 3/4 of maximum (speaker disconnected) and a voltmeter. JL has a tuning procedure that has you increase input sensitivity to 44.7 VAC for an optimal gain setting. I don't touch the "Boost" setting on the Parametric EQ.
I do notice a difference in sounds when playing rock vs. R&B. If I'm using iTunes from the Mac mini I just adjust the iTunes equalizer to the music type. In the rare circumstance I'm playing directly from the head unit, I adjust the subwoofer gain on the head unit to balance the signal.
Old Jan 29, 2008 | 09:04 PM
GQQSE13's Avatar
my new kicker amp has to be set to "subsonic" aka low pass filter or else the amp shuts off with any try of bass to it because w/o it it thinks its powering components
Old Jan 29, 2008 | 09:21 PM
tCeeJay's Avatar
what does that have to do with Bass Boost?
Old Jan 29, 2008 | 09:22 PM
nebster's Avatar
i was wondering the same thing, i think he just wanted to say somthing
Old Jan 29, 2008 | 09:33 PM
Strictly Scionized
LAWLS
Old Jan 29, 2008 | 09:35 PM
nebster's Avatar
Originally Posted by trialsindude
noob
rqftmftae
for those who don't know
re quote for the mother ____ing truth and emphasis
Old Jan 29, 2008 | 09:40 PM
Maybe he meant something else. On the JL amp, the "Boost" setting will only function with the Low Pass filter on 12 or 24 dB. With it off, boost is disabled to prevent cascading the processing of multiple amplifiers when configured in a master/slave arrangement.
