{help} Is it safe to mount my HID ballast here?!
Old Jan 29, 2008 | 08:10 PM
SoleLaced's Avatar
Default {help} Is it safe to mount my HID ballast here?!
Hey guys. i just the mobile HID kit in the mail today. I went to install it and I wanted to install it somewhere you wouldnt see it.
I opted out to install it by the radiator support. I was wondering what this "black box" thing does? Is it safe to mount my ballast right above it? There are 2 of them.....one on both sides.
Its the black box right below my ballast. Is it the airbag sensor? I hope not.
I loosened it so I could tuck the metal tab behind it; and then I retightened it. IS THAT SAFE?!
Old Jan 29, 2008 | 08:24 PM
TeeCizzle's Avatar
Yea if u have the Plastic Splash guard on...Should be safe...
Then again I mounted my Driver side Ballast on the strut wall...and the passenger on the body frame.
Old Jan 29, 2008 | 08:27 PM
SoleLaced's Avatar
Noooo that didn't answer my question.
Hahha. What does that black box do? and is it safe to mount it there?!
Old Jan 29, 2008 | 08:30 PM
recliner15's Avatar
your fine
Old Jan 29, 2008 | 08:49 PM
SoleLaced's Avatar
Originally Posted by recliner15
your fine
really? What is that black box for anyway?
Old Jan 29, 2008 | 08:52 PM
jasonrs2's Avatar
1UP Crew
i think its an airbag sensor. just a guess.
Old Jan 29, 2008 | 09:00 PM
SoleLaced's Avatar
eeek. shoot. So is it safe to mount it there if it is the airbag sensor?
Old Jan 29, 2008 | 09:05 PM
dannygenio's Avatar
it's is the airbag sensor...
Old Jan 29, 2008 | 09:12 PM
SoleLaced's Avatar
Hmm, so its the airbag sensor i loosened the bolt on....
is it going to affect anything cause I mounted it there? I retightened everything. Is that safe?!
Old Jan 29, 2008 | 09:13 PM
jasonrs2's Avatar
1UP Crew
you should be alright, as long as you dont crash. jk, you're alright putting it there. i think the sensor works at the angle the car is in with relation to the ground. for example, if you were to run your car off a cliff, the airbags would go off because that sensor is telling the ecu that the car was angled straight down at the time of impact. i think thats how those there work. dont take my word for it though.
Old Jan 29, 2008 | 10:44 PM
BZinn1's Avatar
It should be fine.....if airbags did not go off when you removed it and have not gone off after install then you are good..........good then to remember is to remove battery cables before starting work on electrical side of car.......that way nothing is in standby and working..........
Good spot to put them till you are on adark road and your lights go out..........JK.........
Old Jan 30, 2008 | 05:33 AM
SoleLaced's Avatar
bump
Old Jan 30, 2008 | 05:49 AM
andino's Avatar
i have mine mounted there no problems. driven through numerous rains now and still running strong
GloStiX
Scion tC 2G Aero & Exterior
May 26, 2015 01:59 PM
lovemyxb333
Apr 3, 2015 01:40 AM
GoodVibes
Mar 10, 2015 04:29 AM
jaspercanda
Dec 28, 2014 10:09 AM
