Power Shuts Off!!
Old Feb 28, 2008 | 08:34 PM
DjTwitcH's Avatar
Default Power Shuts Off!!
Ok... I installed my system yesterday.
sounds grate, only one problem.
When i turn my volume up about more than half way.... the speakers, amp, and subs stop working but the deck continues doing what its doing. theres just no sound. and it doesnt come back on untill i shut off my car and turn it back on.
Whats the problem??
i was told from a couple of my friends that it was because its not pulling enough power and the amp is trying to hard to produce power n it over heats so it shuts off.
They also told me getting a compacitor will fix the problem.... true or fauls???
any body know why this would happen???
(sorry about my spelling)
Old Feb 28, 2008 | 10:27 PM
tCeeJay's Avatar
what amp are you using? what gauge wire did you use? give more details to your setup. The more info u give, the better we can diagnose the problem.
Old Feb 28, 2008 | 10:38 PM
808tC's Avatar
do the lights on your amp turn off or are they still on?
Old Feb 28, 2008 | 11:06 PM
DjTwitcH's Avatar
I have a Profile California 1200 Watt Amp, and i used a 4 gauge Monster amp kit.
The lights on my amp do turn off.
Old Feb 29, 2008 | 06:24 AM
DjTwitcH's Avatar
Please guys... i really need to know.
Old Feb 29, 2008 | 07:32 AM
rocketgyrl's Avatar
Default Re: Power Shuts Off!!
Whats the problem??
It sounds to me like your ground isn't sufficient. Where exactly did you attach the ground wire? Did you sand down the paint to the bare metal? Did you use a stainless steel screw? You should consider relocating it to a thicker gauge of metal - found near the perimeter of the car.
My advice is to thank them for their help, but ignore their suggestions. Capacitors have been covered numerous times - just search. The short answer is they will NOT cure your problem. I'm not sure how to respond to the other things they've told you - as it doesn't make much sense...
Old Feb 29, 2008 | 08:15 AM
ih8civx's Avatar
check your ground bud... Make sure wires arent toughing once the speakers start moving air...
Old Feb 29, 2008 | 04:04 PM
DjTwitcH's Avatar
Ok... Ill make it this alot easer... when i get home... i'll take a pic of where my ground where is at and tell me if its right. give me a little time... im at school right now. lol.
My friends told me to get a compacior cause im not gettin enough power to my amp and my amp is trying to work to hard to produce the power so it over heats and shuts off. but that doesnt explain why my speakers would go out cause there the stock speakers
i was also told today that it could be the battery... its not large enough.
Old Feb 29, 2008 | 04:16 PM
tCeeJay's Avatar
which battery do you have? Mine's the stock battery and my 2 amps (a 6channel sending out 300w RMS total and a mono sending out 1000w @1ohm) never shuts down.
Old Feb 29, 2008 | 04:23 PM
DjTwitcH's Avatar
I also have the stock battery.
Old Feb 29, 2008 | 08:25 PM
DjTwitcH's Avatar
NEVER MIND... ALL DONE!!! thanks for the help guys!!! all i needed was a premium 2 ch adjustible line output converter cause the rca outputs on the deck where sending a bad signal.
JenK
Scion xD Drivetrain & Power
Dec 7, 2020 05:24 PM
Oldtimer
Nov 5, 2019 05:54 PM
JcBgOe
Mar 16, 2015 12:57 PM
eric_m
79
Mar 17, 2013 12:21 AM
crystaljukebox_com
Feb 5, 2004 05:53 AM
