Dust caps
Old Mar 6, 2008 | 06:12 AM
glock32's Avatar
Default Dust caps
I haven't had any luck finding the dust caps for stock 15" wheels. I'm sending my wheels out to get powder coated this week and want to finish it off nice. Does anyone know the part# for NAPA or Schucks or AutoZone dust caps? Thanks in advance.
Old Mar 6, 2008 | 12:44 PM
TheShortBus's Avatar
Check these out at your local NAPA store ($2.80 each): http://napaonline.com/masterpages/NO...+Wheel+Bearing
Old Mar 6, 2008 | 06:01 PM
BoxOffice's Avatar
I got mine from NAPA, but mine are Balkamp P/N 730-2411.
(Not sure if the above listing is correct?)
They're a very tight press-fit, and work like a charm!
Here's a close-up:
Old Mar 6, 2008 | 11:19 PM
Shan14's Avatar
Here's the major dustcap thread: https://www.scionlife.com/forums/viewtopic.php?t=111710 ('Bling Trim Rings with solution')
Old Mar 7, 2008 | 01:11 AM
glock32's Avatar
Thanks for the help.
Old Mar 7, 2008 | 01:37 AM
ItsmeJSB's Avatar
please post pics of your steelies once you get them back from being powder coated thanks
Old Mar 7, 2008 | 02:13 AM
rhin0sb's Avatar
how much does it cost to get steelies powder coated?
Old Mar 7, 2008 | 07:10 AM
glock32's Avatar
I had decided to use powder coating because I was told it would be a long lasting, shiny finish. I was quoted $40 per wheel for powder coating. When I brought the wheels in this morning, they then told me because the wheels were painted and clear coated and not bare steel, it would ba an additional $40 per wheel.
I called several body shops and got quotes from $150-250 to paint and clear coat my set of wheels.
So, it looks like I'll be painting the wheels myself. Most of the steelies I've seen have been stock black, which is how my xB has spent half it's life, so I'm looking forward to seeing how these turn out in matching Polar White. Should be a nice contrast with the tires.
I will post pics as soon as they are done.
Old Mar 7, 2008 | 10:24 AM
ItsmeJSB's Avatar
nice ! Gotta luv a polar white box. waiting for the pics ...
Old Mar 8, 2008 | 02:54 AM
glock32's Avatar
I plan on working on the wheels Monday. I picked up the caps at NAPA for less than 10 bucks, and high gloss Krylon paint, primer and supplies for another $25. I can't wait to see how it turns out. Again, thanks for the info and encouragement.
Old Mar 8, 2008 | 01:44 PM
stew32's Avatar
I used high temp silicone to glue my dust caps on. I tried to just pressure fit, but I lost one within a few days. They're also easily dented. These work OK, but it seems like we should use a smaller size to actually fit in the hub (like these are intended) instead of outside the wheel lip?
Old Mar 8, 2008 | 02:24 PM
bB2NER's Avatar
Music City Scions
The solution I used to hold the caps on tighter was to use some aluminum tape. It comes in a roll. Cut a strip of it long enough to line the inside lip of the cap. I made my strips about 1/2 inch wide. It made it a much tighter fit and have not lost one yet. You could also use some trim adheasive for added measure. Can't wait to see the finished product Arnie. I may do mine in silver sometime.
Are you using paint that needs hardner added or spraycan enamel? If using spraycan stuff, look for either engine enamel, epoxy or paint meant for wheels to withstand the heat the wheels receive.
Old Mar 9, 2008 | 12:23 AM
glock32's Avatar
It was 60 degrees today so I primed and painted the wheels and dust caps. I'll wait till Monday to give a second coat and shoot the clear. They are looking good.
Old Mar 9, 2008 | 01:38 AM
bB2NER's Avatar
Music City Scions
Good deal, can't wait to see them. My Yaris caps came in today and look nice.
Old Dec 29, 2008 | 01:06 AM
stew32's Avatar
Doh! Lost another one last week. I'd used high temp silicone to glue on the replacement and one other that was loose. When I swapped on the snow tires this year, the two pressure fit caps were still on solid. Guess I hit a few too many pot holes.
Old Jan 1, 2009 | 07:10 PM
saddlesore's Avatar
Default Re: Dust caps
Are ya gonna do them in white and where in Salem are ya taking them?
Also I got ta set of stainless rings @ Hubcap Annie for $55 plus $5 shipping.
their phone ## is 800.627.7880
http://hubcapnetwork.com
hubcapannie@hubcapnetwork.com
Old Jan 13, 2009 | 04:02 PM
krispies13's Avatar
I always found those covers so sexy...
yupinmytC
22
Jul 27, 2024 07:08 PM
dougcbx
Oct 23, 2015 11:42 PM
user9430961
Sep 24, 2015 01:09 PM
Mjdavis1994
Sep 21, 2015 04:42 AM
paisatronix
Sep 5, 2015 04:13 AM
