HIDS! 6000k Help Please
Old Mar 11, 2008 | 05:21 AM
Tom11x's Avatar
Default HIDS! 6000k Help Please
Last night i had a huge problem with my hids. For some reason the left hid headlight was not working. When i flick the lights off and on it makes a noise thru my speakers and it works. But recently, it has not been working that way. I purchased this HID on Xenoneyes.com about a year ago. Please help me solve my problem.
Old Mar 11, 2008 | 05:22 AM
Aroddalobster's Avatar
did you try switching bulbs to see if it's the bulbs or ballasts that are causing the problems?
Old Mar 11, 2008 | 08:25 PM
Tom11x's Avatar
hey guys its working this morning making the big noise thru the speakers. Mostly likely its not going to work later. what should i do
Old Mar 11, 2008 | 08:40 PM
5hift_gear's Avatar
You have to give us more info then that.
First did you connect it directly to your OEM harness ? or did it come with it's own harness. Where did you ground it ?
Did you try switching bulbs from either side ? Try just plugging in your normal bulbs and see if this is a HID problem or a bad ground from somewhere else.
Old Mar 12, 2008 | 03:31 AM
Tom11x's Avatar
Srry about the info. The HID kit is a plug and play. i just wire the hardness to the ballast and lock the blub to the headlight.
This happen ever since i install my avic d3 navi from a local stereo store.
Is it the ground wire from the avic d3 is in a bad location.
update:
I realize today when i turn on the HID lights the left side is not working and the right is working
It takes about 20mins until there is squeak noise thru my speakers and the left hid light is on.
Once i turn it on its the same process over and over
thank you
Old Mar 12, 2008 | 03:47 AM
BZinn1's Avatar
Ballast will make noise as they age........they get a hum..........in a 12v system the hum can be picked up throughthe speakers pretty easy........they act like a toner......check all your grounds.........then check the ballast.
Old Mar 12, 2008 | 08:39 AM
striker_1818's Avatar
bad ground
Old Mar 12, 2008 | 05:04 PM
5hift_gear's Avatar
I'd tried taking it back to the local stereo store and seeing where they grounded the AVIC.
For now I suggest just taking out your HID's so you can prevent damage to both your ballast, bulbs and potentially your car's OEM harness. Better safe then sorry.
Old Mar 13, 2008 | 02:33 AM
Tom11x's Avatar
thanks a lot. well its working right now. but still making the noise. im about check back at the local stereo sunday. ill update when i finish
Old Mar 13, 2008 | 08:01 AM
noise is ground issue. Not powering on or ballast powering on when it feels like is caused by the ballast itself.
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
hondajt
Dec 14, 2015 12:54 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Renuco612
Sep 16, 2015 09:01 AM
