Lanzar (vibe-246) and Audiobahn AW1051T hookup?
Old Mar 19, 2008 | 03:54 AM
zippox's Avatar
Default Lanzar (vibe-246) and Audiobahn AW1051T hookup?
Ok so heres what I got:
* 2 x 300W RMS at 4 OHMS 2 x 600W MAX at 4 OHMS
* 1 x 1200W MAX at 4 OHMS Bridged 2 x 500W at 2 OHMS RMS
* Electronic Crossover Network
* Bass Boost Circuit
* 2 Ohms Stereo Stable
* Anti-Thump Turn-On
* Illuminated Top Panel
* Soft Turn On/Off
* High & Low Level Inputs
* Power & Protection LED Indicators
* Advanced Protection Circuitry
* Remote Control Bass Booster
* THD: <0.04%
* S/N Ratio: >90dB
* Channel Separation: >65dB
* Freq. Response: 15Hz~35kHz
* Dimensions: 11.06''W x 2.24''H x 13.5''L
I have two of these and they are: (link is http://www.amazon.com/Audiobahn-AW10...897951&sr=8-10)
*Dual 4 Ohm 300 Watts RMS
So my question is, how should I wire these? What I did (which i believe is wrong) is on each of the subs did positive to negative. Then I did negative on sub to negative on the box and positive on the sub to positive on the box. Is this correct?
If not, which one of these diagrams should i follow? (its a list of crutchfield suggestions wirings)
http://www.crutchfield.com/learningc...rs_wiring.html
As how I see it, is that i should just do it straight up. positive on sub to positive on box and negative on sub to negative on box.
Old Mar 19, 2008 | 03:59 AM
mixmaster's Avatar
Default My friend used to sell Audiobahn at his shop and can help
Illusions Audio ask for Bill 610-695-9330 he can give you the advice you need open till midnight 7 days a week.
Audiobahn is an expensive equipment I had it in my BMW and you want to make sure you wire it to the specs of the manufacturer.
Old Mar 19, 2008 | 05:12 AM
zippox's Avatar
Just talked to him. Great guy. Helped me figure out just about everything.
He said i should get 2 gauge amp kit, and right now i have 8 gauge. is this necessary?
The way he said for the wiring was to bridge the (+) and (-) together on each sub, then wire the (+) on sub to (+) on box and same for (-). Then i need to twirl the two positive wires coming outa the box and put that in the amp and do the same for the negatives.
totallyboardz
41
May 3, 2005 05:25 PM
hotbox05
Apr 1, 2005 12:35 AM
The0ckid82
24
Jan 18, 2005 12:14 AM
bajamike
Dec 23, 2004 01:28 AM
Reign_Man
26
Dec 19, 2004 08:07 AM
