oil pressure fuel sandwich adapter
Old Mar 19, 2008 | 01:06 PM
Dkfung88's Avatar
Default oil pressure fuel sandwich adapter
so i've been looking all night, and all i found was glowshift fuel sandwich adapters but i also found that a couple of people who had this had problems with the oil filter just popping off... are there another manufacturer who makes these oil adapters that they're using and its working for you? or am i stuck with glowshift ones? i think i have to get a 3/4 one if i do plan to get it but what size oil filter should i use?
Old Mar 19, 2008 | 02:48 PM
Dkfung88's Avatar
anyone anyone???
Old Mar 19, 2008 | 05:37 PM
Dkfung88's Avatar
anyone anyone??
Old Mar 19, 2008 | 06:25 PM
Mr_Meaty's Avatar
Greddy makes one in a kit....but I just sold mine, sorry.
Old Mar 19, 2008 | 07:58 PM
Dkfung88's Avatar
have you ever used it? any problems?
Old Mar 19, 2008 | 08:38 PM
Mr_Meaty's Avatar
works fine...much better then the glowshift.
Old Mar 19, 2008 | 09:59 PM
Red_tC's Avatar
I have a glowshift one and I wouldn't recommend it because there is a small leak. A buddy of mine has one as well and he has had lots of leaking problems with it.
Old Mar 19, 2008 | 10:00 PM
Dkfung88's Avatar
what kind of filter did you use? just the stock oil filters that fits the tC?
Old Mar 19, 2008 | 10:03 PM
Mr_Meaty's Avatar
It will fit with the stock filter.
When I was using it, I had it once with the stock Toyota filter (which are actually the best ones), once with a mobil1, and once with some "JDM" filter my tuner put on there
All fit fine.
Old Mar 19, 2008 | 10:07 PM
Dkfung88's Avatar
thankyou thankyou
now........... how hard is it in install one? lol
oh and the oil sandwich adapter is 3/4 umf 16?
Old Mar 19, 2008 | 10:51 PM
Mr_Meaty's Avatar
Originally Posted by Dkfung88
thankyou thankyou
not sure what 3/4 umf 16 is, but it's really easy to install.
When you go to change your oil, you take off yoru old filter.
Then, you screw the adapter in using the center bolt that is supplied with the kit.
This brings the bolt for the oil filter down further to compensate for the thickness of the adapter (I beleive this is where the glowshift has a problem) Tighten down the bolt.
Then you simply screw your oil filter into teh new extended bolt.
obviously you would pick which fitting to undo for whatever gauges or whatnot you are connecting to the adapter.
Old Mar 20, 2008 | 12:49 AM
yamaha16bw's Avatar
I use the greddy one shown and its has worked fine for over a year.
Old Mar 20, 2008 | 12:50 AM
Dkfung88's Avatar
if its not a problem.. can you take some pics on how your wires are hooked up? including the gauge
Old Mar 20, 2008 | 06:24 PM
JL56TC's Avatar
I hve a glowshift and I put some hi temp gasket maker beween the 2 rubber seals. It has never leaked... however If you dont teflon tape evruthing I could see how there would be a problem. The other thing I would suggest is trying to find a thermal oil sandwich plate b/c it will close if it gets too cold. It may take some inovation but you gotta find out what works the best for you.
Old Mar 22, 2008 | 03:49 PM
SoccerBoy_AP's Avatar
/ditto
Must Use Teflon!!!
I have a glowshift one and running w/o leak
Old Apr 20, 2008 | 11:12 PM
rockbrawler884's Avatar
I was running a GlowShift sandwich adapter for 1 year under boost applications... ZERO leaks... use Teflon!
my06tc
Jun 25, 2015 12:18 AM
yhwhdesign
Mar 7, 2015 02:01 AM
k1114
Mar 6, 2015 03:43 PM
cid_mcdp
Jan 5, 2015 02:45 PM
eric_m
79
Mar 17, 2013 12:21 AM
