Front suspenion noise
Old Mar 26, 2008 | 12:57 AM
Tenfeathers's Avatar
Default Front suspenion noise
Does anyone notice a souund like something looose around the front shock area only when you hit certain dips or bumps. Or is it my imagaination .
2008 XB
Thanks in advance
Paul
Old Mar 26, 2008 | 01:38 AM
coryjames's Avatar
mine does it to hmmmmmmmmmmmmmmm wonder what it is i thought it was my coilovers so the other day i put in my stock struts real fast and it still does it
Old Mar 26, 2008 | 10:19 PM
I have checked every dam bolt on the front end, it really feels like a bad shock with no fluid in it. But it doesn't bounce like it would if the shock was bad.
I felt it a little more today in the streering wheel, I'll check that
Thanks
Old Mar 27, 2008 | 03:07 AM
az_pinoy's Avatar
weird, I thought I was the only one too that was experiencing it.
JC
Old Mar 27, 2008 | 03:24 AM
xseveredveganx's Avatar
Utah Scions
Is it the infamous creak?
Old Mar 27, 2008 | 04:56 AM
coryjames's Avatar
not the crreeek its from the suspension i got the creak fixed well made worse by the dealer
Old Mar 27, 2008 | 05:29 PM
AAG's Avatar
AAG
DeepSouth Scions
I have a "thud" sound when I hit certain potholes. Doesn't really bother me though.
coryjames, sucks that the dealership made the "fix" worse. When I saw what the process was when fixing the problem, I knew I would just live with it.
Old Mar 27, 2008 | 06:20 PM
MikeInABox's Avatar
I've found something that I'm pretty sure is making an annoying noise on mine.
Whenever I'm stopped and give it gas, or moving and hammer it, there's a clunking type noise on the driver side.
With the door open, in the front where the fender mounts to the body, there's a plastic liner type thing between the fender and the body. Goes all the way from the rocker panel up to the bottom of the A pillar. I pushed on it and it moves quite a bit back and forth. I think when I give it gas, it's coming back and hitting the metal and making the noise. That's my guess on my noise anyways.
EDIT: It also does it on bumps sometimes.
Old Mar 27, 2008 | 09:49 PM
I haven't considered the plastic in the wheel well, but your noise sounds like mine drivers side.
If I find it I'll post it
Old Mar 28, 2008 | 02:48 AM
generem's Avatar
I have the same noise / clunk feel on the steering wheel. . it was faint before I dropped my car but more noticeable now. But mostly when turning the wheel on a slow turn. I've checked all bolts and they were fine. I couldnt find anything with too much play either
Old Mar 29, 2008 | 12:05 AM
It may be just the nature of the beast, but it's driving me crazy hope someone figures it out.
Thanks everybody
Old Mar 29, 2008 | 12:06 AM
coryjames's Avatar
mine is in the one two shift and yeah i dont know but it does it with my stock struts to so who knows maybe its just the motor flopping around who knows
Old Mar 30, 2008 | 09:50 PM
generem's Avatar
I was parked in a parking garage a weird way and had to do a 3 point turn to get out of a parking spot. I really think its somewhere in the steering assembly. Maybe a pivot joint?
Old Mar 31, 2008 | 12:42 AM
Zsanz's Avatar
i hear it over speed bumps every now and then does it wehn its really cold
Old Mar 31, 2008 | 01:20 AM
Yep now we're on to something, COLD temp. and small bumps and turns in steering, maybe has something to do with the power part??????
DaBlackBox
134
Apr 10, 2022 02:04 PM
scotttie17522
Feb 23, 2020 08:38 AM
hampton1100
May 28, 2015 07:32 AM
meowtc
Mar 5, 2015 02:28 AM
fur_pig
Dec 5, 2014 12:48 PM
