Front suspenion noise
Does anyone notice a souund like something looose around the front shock area only when you hit certain dips or bumps. Or is it my imagaination .
2008 XB
Thanks in advance
Paul
2008 XB
Thanks in advance
Paul
I have checked every dam bolt on the front end, it really feels like a bad shock with no fluid in it. But it doesn't bounce like it would if the shock was bad.
I felt it a little more today in the streering wheel, I'll check that
Thanks
Thanks
I have a "thud" sound when I hit certain potholes. Doesn't really bother me though.
coryjames, sucks that the dealership made the "fix" worse. When I saw what the process was when fixing the problem, I knew I would just live with it.
I've found something that I'm pretty sure is making an annoying noise on mine.
Whenever I'm stopped and give it gas, or moving and hammer it, there's a clunking type noise on the driver side.
With the door open, in the front where the fender mounts to the body, there's a plastic liner type thing between the fender and the body. Goes all the way from the rocker panel up to the bottom of the A pillar. I pushed on it and it moves quite a bit back and forth. I think when I give it gas, it's coming back and hitting the metal and making the noise. That's my guess on my noise anyways.
EDIT: It also does it on bumps sometimes.
I have the same noise / clunk feel on the steering wheel. . it was faint before I dropped my car but more noticeable now. But mostly when turning the wheel on a slow turn. I've checked all bolts and they were fine. I couldnt find anything with too much play either
DaBlackBox
134
Apr 10, 2022 02:04 PM
hampton1100
May 28, 2015 07:32 AM
fur_pig
Dec 5, 2014 12:48 PM
