Adding LEDs to the dimmer knob?
Old Apr 5, 2008 | 06:45 AM
HondAudio's Avatar
Default Adding LEDs to the dimmer ****?
I kind of want to put some amber LEDs in the little compartments around the steering wheel. Has anybody tapped into the dimmer switch to run LEDs? Is there somewhere else I can tap into that will turn them on with the parking/headlights and let them be dimmable?
Old Apr 5, 2008 | 02:06 PM
PL_Ramses's Avatar
i put in white gauges(temp, oil,volts) they have white led's and i tried to hook them up to the dimmer but it doesn't work. Very interested in info also.
Old Apr 5, 2008 | 10:35 PM
HondAudio's Avatar
What brand? Got any pics? I want to put in a voltmeter
Old Apr 11, 2008 | 07:48 AM
HondAudio's Avatar
...Bueller?
Old Apr 11, 2008 | 02:56 PM
Forklift's Avatar
you have to make sure that the LEDs are either 12v ones (with built in resistor) or hae the external resistors that HAVE to be hooked up. ALso you need to make sure of the direction of them as the D stands for diode which means they are a one way electronic valve.
I did it, it wasnt fun
Old Apr 12, 2008 | 12:43 AM
HondAudio's Avatar
What am I looking at?
Old Apr 12, 2008 | 02:21 AM
jct's Avatar
jct
your dimmer switch along with your headlight switch can take the load of the led's i have many of 'em in my car hooked up to them... power wire comes from the headlight switch wiring and the ground is the dimmer switch wiring
YooItsJay
Dec 2, 2015 08:13 AM
missing_image
Feb 7, 2015 07:18 PM
minter66
Dec 15, 2014 01:45 PM
crystaljukebox_com
39
May 14, 2004 04:55 AM
KingLou
15
Mar 3, 2004 07:11 PM
