05+ mustang shift knob... how many of you have it?
hey guys i just bought a 05+ mustang shift **** on ebacy because i thought it would match the interior on the tc really good. i havent gotten it in yet but i was wondering if anyone else on here has one?
if so does it sit higher then stock?
is a screw in type?
does the stock boot fit?
how does the colors match?
thanks
is a screw in type?
thanks
Originally Posted by amp0804
There are already a few people that have had it. Look in the shift **** thread.
i have it.. its about the same size as the stock shift ****.. u have to cut this little plastic circle off the bottom of the mustang **** (ull understand when u get hte ****).. it fits pretty nicely with teh stock shift boot.. colors match pretty well..
cheers
cheers
^^ oh yeha.. i got a short shifter now sooo... yeahh.. come to think of it.. it did sit a bit higher then the stock knobl.. hahaha... ill try to get u some pics of it witht he megan short shifter
alright man thanks that be great... if it does sit a bit higher im not worried. im gonna be getting a doc-i short throw shifter anyways .. im just not sure how much of a drop i should get.
thanks again
thanks again
hahaha when i first got it i was like "$#%@$^ now i have to get short shifter..." but instead of spending the money on one i just cut it down like 1.5in and re threaded the shaft.....works perfectly. the only thing i regret is cutting the "knotch" below the ****....when you get yours just take off the chrome piece and slide teh boot over the piece that the mustang **** has...thats what its for....it will look 10x better...if you do decide to cut it, you will have a chrome and aluminum ring together...but heres mine....it matches the waterfall perfectly
when you cut it down 1.5" was it sitting at the same height as stock or was it lower?
my goal is to have the **** be about 1" lower then the stock one so im not sure what shifter height i should get yet
thanks
thanks
yea you could definantly tell that it was shorter. you feel the difference too....you dont even get that feeling of having to reach out to shift...its just there...its perfect
It's a 2" height reduction, also I didn't us the oem collar, I just pulled the boot up over the collar piece on the **** and zip tied it from underneath to keep the boot from slipping off the ****.
wow looks like its a perfect match color wise
cant wait to get mine in... i think im gonna order a 1.5" reduction on my shifter you think that would be good for this ****?
if so does it sit higher then stock? sits about the same
is a screw in type? yes
does the stock boot fit? if you have sotkc shifter you can stretch the boot to fit but it usually pops off when shifting gears, get a short shifter with a height reduction and itll fit fine. (i have 2" reduction)
how does the colors match? good
Originally Posted by unxpectederror
forgot to ask how does the **** feel compared to stock, do you like it better or not?
ive slipped gears a couple times cuz of it though.
the sides are like leather but the top is a kind of plastics and gets slippery if your palms are sweating.
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
