Regional - Mid Atlantic DC, DE, MD, VA, WV
won't idle
Old Jul 1, 2008 | 12:05 PM
wubby24701's Avatar
Default won't idle
I have a 2006 XB can't keep the thing running idles ruff and misses while while driving was told by one scion dealer it was bad gas, paid that bill now after 3 gas tanks of new fuel I took it to another scion dealer now I am being told it is a ecu has any one else experience this the xb has 78000 miles on it and I boughtit new and this is the only problem I have had with it.
Old Jul 1, 2008 | 02:05 PM
BrEaK_AwaY's Avatar
have you installed a intake? whens the last time you changed/cleaned your air filter?
Old Jul 1, 2008 | 02:32 PM
BroketC's Avatar
Could be in need of a tune-up, perhaps cleaning of the MAF sensor, or like Zach said, the intake could be dirty or the filter could be causing it...
I would suggest posting this thread in the xB forum, if you get no answers there, perhaps check out the Scikotics website, there are a good deal of xB owners that may have the information you need to get yourself squared away.
Old Jul 3, 2008 | 10:34 PM
cncptc's Avatar
Make sure you don't have a vacuum hose off somewhere. You will here a sucking noise, and if's bad enough, the car will run bad, and or stall.
Old Jul 3, 2008 | 10:40 PM
CDogbert's Avatar
My 240 had a loose MAF sensor that caused this. Does it idle normal, dip down until the car shudders, and then rev up again?
I would definitely go over your whole intake system with a fine tooth comb and make sure everything is spotless.
Old Jul 4, 2008 | 03:47 AM
wubby24701's Avatar
Default won't idle
thanks guys I am checking the map sensor tomorrow the shop told me that scion said they would help me to fiqure it out I will keep you up dated on the progress
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
steeze69
May 24, 2021 02:57 AM
OpTicaL
Sep 16, 2015 10:25 AM
mikeac
Sep 15, 2015 03:24 PM
