engine knocking
Old Jul 8, 2008 | 05:14 AM
Soupy_TC's Avatar
Team No Limitz
Default engine knocking
well everyone the tC looks like its deciding to quit on me... about 2 days ago I started hearing a pretty loud knocking sound when I press the gas.. I don't notice any performance loss but it sure is annoying and really doesn't sound healthy.. Tonight I changed the oil and added some stuff that says it "quiets engine noise".. I think thats a bunch of bull but anyways after running it around the block nothing has changed... any ideas?? if nothing works then time to trade it in.. please help..
Old Jul 8, 2008 | 05:16 AM
Ace83's Avatar
Ronin Scion
is it bone stock? no engine mods? have it checked for warranty if still qualified, if with mods then its the tune.. or try resetting the ecu maybe the tune is messed up.. and yeah happened all of the sudden?
Old Jul 8, 2008 | 05:40 AM
jamesfg49's Avatar
Default Re: engine knocking
Soupy, sounds like your main bearings are shot.
What the knocking is either the crankshaft hitting the bearing (your talking about hundreds of thousands of an inch) as it rotates or a rod bearing hitting the crankshaft. It eventually will get worse and egg shape the bearing and then eventually (key word there) let loose and the rod will go out the side of the block.
If your gonna trade it in, put straight 30 weight in the car and drive it over to the dealership. Should hold you over til you get the dealer to look at it and give you a number on the car for trade in value. The 30 weight is so thick it will quiet the knock down for a bit.
Old Jul 8, 2008 | 06:01 AM
Garage1217's Avatar
Hey soup, is yours an 05? Just curious as they revised the bearings on the 06+. If you need help finding a low milage engine locally, let me know. You can usually snag one for about $1000 or so.
Old Jul 8, 2008 | 04:03 PM
Soupy_TC's Avatar
Team No Limitz
its a 06 with 70,000 miles.. looks like i'm screwed
Old Jul 8, 2008 | 04:15 PM
Garage1217's Avatar
Wow that stinks man. Well like I said, 2az engines are pretty easy to come by for not a lot of cash.
Also one of the reasons I will not run 0 weight oil in my car as toyota now wants us to do. I am used to getting 250-300K miles out of a motor. Lowest I am running right now is 5w30 in the summer. I feel running practically water in a motor will have a lot of negative effects on a motor in the long run such as the issues you are having. Just my humble opinion though.
go to www.car-part.com and enter AZ & look for a motor made after 05-2006. Tons of motors with low milage for around $1200
Old Jul 8, 2008 | 07:57 PM
Just1n's Avatar
Wagonistas
WOW that sucks dude...
Old Jul 10, 2008 | 02:48 AM
sequel's Avatar
If it's knocking, why don't you answer it? Ha! But in all seriousness, I drove about 8,000 miles with a spun rod bearing, these motors are HARD to kill.
Old Jul 10, 2008 | 02:56 AM
Scisko's Avatar
Scionetics
Go get a Toyota Tocoma from Chad @ Camelback Toyota. But hide the spare for about 1 month and you will live happily ever after! Camelback Toyota, not any were else and you will get ripped off and done in good with no KY!
Old Jul 10, 2008 | 03:10 AM
turbotc06's Avatar
is it a hollow tap or a actaul knock ...theres a difference in locations too
i have a hollow tap ...its a lifter but no one knows what to measure so its ____ing me hard
soooooooooooo thats that lol
Old Jul 10, 2008 | 07:50 PM
Soupy_TC's Avatar
Team No Limitz
its DEAD!!! i killed it on the way home kast night.. Time for a new engine
Old Jul 10, 2008 | 07:55 PM
equinox2355's Avatar
Lame! Sorry to hear that. By the way when was your tC manufactured? Early 2006 tC's have the 2005 motor (and the issue with bearings) If its early 06 then thats what happened to others (and most likely mine too).
Old Jul 10, 2008 | 11:56 PM
Soupy_TC's Avatar
Team No Limitz
Thanks Jeremy... I picked up one from that site.. Looks pretty good.. We'll see when it comes to installing it..
Thanks to everyone else for your input and ideas..
Old Jul 11, 2008 | 01:56 AM
Garage1217's Avatar
Look it over close. Which place did you buy it from? Did they offer a warranty?
Old Jul 11, 2008 | 07:38 AM
Soupy_TC's Avatar
Team No Limitz
i got it from a place here in Tucson... The car it came out of was rear ended with NO damage to the front.. Insurance totaled the car and so they are trying to piece it out... looks clean with 30k on it
yoson13
Scion xA Aero & Exterior
13
Aug 29, 2015 11:12 PM
D_Roke
Mar 31, 2015 05:37 PM
xa007xa
Feb 22, 2015 03:02 PM
eric_m
79
Mar 17, 2013 12:21 AM
BlueBox
14
Jan 15, 2004 01:08 PM
