problem with avic-d3 and swi-ps
Old Aug 2, 2008 | 11:41 PM
kikkomanrj's Avatar
Default problem with avic-d3 and swi-ps
I've got everything working except I can't program the MODE button on the steering wheel to do anything. The volume +/- and up/down arrows work it's just the MODE. I'm about to plug in the factory HU (2006) to see if theres a loose connection with the button. Anyone else experience this?
Old Aug 2, 2008 | 11:53 PM
SquallLHeart's Avatar
i haven't heard any problems as long as the wires are all connected properly.
programming can be a little time consuming and compicated, but the instructions they give are pretty easy to understand.
i'd check the wire connections to the pac-swi first before doing anything with the stock headunit going back in.
if you haven't taken the steering wheel apart at all, there's no reason why there should be anything loose there.
also do note that the pac-swi does exhibit a lag between button presses and headunit response.
Old Aug 3, 2008 | 01:55 AM
kikkomanrj's Avatar
All clear. The initial problem was when I was programming, the LED on the SWI wasn't turning off to indicated that the button was learned. When I did plug in the stock HU hehe, the test was inconclusive. The only button that worked was the vol +. I started over from the beginning (reconnected the SWI, clearing out the programming) and everything worked.
Old Aug 3, 2008 | 02:02 AM
sweet deal
glad to hear it all worked out
RY_TC07
Jul 18, 2017 05:18 PM
bravosixniner
May 24, 2015 09:56 AM
ScionXa06
May 18, 2015 10:05 PM
claiknx
May 17, 2015 11:44 PM
Moth
Apr 14, 2015 12:17 AM
