Clutch or Transmission problem?
Old Aug 10, 2008 | 10:47 PM
jeems's Avatar
Default Clutch or Transmission problem?
Here lately I've been having a difficult time shifting in my 2005 Xb.
I've been freqently grinding gears and its not due to my shifting. It just seems like it takes a little more force to shift into the next gear.
Could it be the clutch fluid possibly? But in an '05?
Do I need to replace my clutch?
Possibly buy a short shifter?
Old Aug 10, 2008 | 11:57 PM
stew32's Avatar
Default Re: Clutch or Transmission problem?
Sounds like you just need to change your trans oil. I had to change my 2006's at about 12k miles because it had gotten a little more difficult to shift and I was occasionally missing a shift.
Make sure you use a synthetic GL-4 oil that's for manual transmissions (like Redline MT-90), not a GL-5 that's for differentials. Most of what you'll find at auto part stores is GL-5 or non synthetic GL-4 so it may take some searching or even ordering online.
Old Aug 11, 2008 | 02:07 AM
Zombietime's Avatar
I used Royal Purple 75W90 in my 05 and got it at Auto Zone. Works great - I highly recommend it.
Old Aug 11, 2008 | 03:12 AM
jeems's Avatar
how much does it usually cost and how much will i need?
i usually take my car in to a jiffy lube to get the oil changed because i'll get a free car wash haha so will they change tranny oil?
Old Aug 11, 2008 | 07:15 AM
hotbox05's Avatar
oh and there's no such thing as "clutch fluid"
Old Aug 11, 2008 | 10:07 AM
Zombietime's Avatar
i paid $15 dollars a bottle and you need two. You may be able to get it cheaper online but I wanted to do it that day.23 50 Jiffy lube probably wont have the good fluid that you want and I wouldn't trust them anywhere near my car anyway.
Old Aug 11, 2008 | 04:38 PM
jeems's Avatar
well brake fluid. i used to have to refill it all the time in my old Honda Passport or else the thing would never go into gear.
Old Aug 12, 2008 | 01:43 AM
Sciond's Avatar
just go synthetic..gear lube and you will befine
Old Aug 22, 2008 | 10:32 PM
Guest
Guest
Posts: n/a
easy job, just drain and fill. No filter to replace. The plugs are in plain view too. :D
Old Sep 14, 2008 | 03:30 PM
Hotokuken's Avatar
I hope that fixes your problem , i dont know how you drive but i beat the christ out of my 06 xa for the first 30k miles treating it like my old honda and it started doing the same thing as yours. Took it to toyota and had to have the trans rebuilt (under warranty of course) my 3rd and 4th gear syncros were shot and the 5th and reverse gear had welded themselves to the input shaft. Since then ive been more aware of my shifting and placed my gears with the clutch fully depressed instead of throwing it into gear. now i shift like that quickly and i havent had any problems since.
Old Sep 15, 2008 | 02:09 AM
FlakoFigZ's Avatar
Yes there "is", lol. I work at AutoZone and we sell a tiny white bottle of Costal brand Clutch Fluid.
evolving_machine
Oct 21, 2023 01:16 PM
rjjablo
16
Feb 19, 2020 12:42 PM
Dmmcclair
Aug 13, 2015 07:14 PM
08bakerXxtc
Mar 19, 2015 09:51 AM
gularti
Dec 4, 2014 01:21 PM
