Scion xD ICE & Interior In-car entertainment and electronics...
sort of newb question but i need to know.
Old Aug 15, 2008 | 04:34 PM
XLR8R's Avatar
Default sort of newb question but i need to know.
how do u take out the stock radio headunit? if u can do it without taking the dash apart that would be nice. i need to know cause im hooking up an RCA converter/adapter.
pics would also help if anyone has some from a previous instal.
thanks.
Old Aug 15, 2008 | 05:41 PM
Oznium_com's Avatar
You sort of have to take the dash apart. Just start pulling on the trim pieces around the radio, remove some bolts
Old Aug 15, 2008 | 08:17 PM
XLR8R's Avatar
like the black trim pieces?
Old Aug 15, 2008 | 11:53 PM
ChelsDS's Avatar
There is a thread around here with instructions on how to remove the dash pieces, known as the watefall.
Old Aug 16, 2008 | 05:21 AM
tmrepp's Avatar
Pull the BSP (Black around the radio and has clock built into it) straight away from the dash. Grab the part up towards the top, and just pull, it'll pop out. Then grab the bottom, and work that out and then unplug the connector from the clock. KEEP THIS CONNECTOR SEPARATE, IT WILL FIT INTO THE RADIO AND BLOW YOUR ACCESSORY FUSE. (15 amp blue fuse under the hood if you do happen to mess it up, not a big deal just a PITA). Self explanatory from there.
Old Aug 16, 2008 | 05:44 AM
XLR8R's Avatar
awesome guys. thanks. any info on how to hook up the RCA adapter?
Old Aug 16, 2008 | 01:08 PM
xravexboix's Avatar
Easiest way is to just get a adapter cable from "headphone jack" (AUX plug) size to "RCA". Those converters should run only about $10. The wiring in the back of the unit starts to get a little funky if you're trying to go direct.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
