anyone hear a thumping kinda noise from the hatch?
Old Aug 20, 2008 | 07:53 PM
tysscion's Avatar
Default anyone hear a thumping kinda noise from the hatch?
when I close my hatch, I hear a loose, thumping sound. Anyone else have this?
Old Aug 20, 2008 | 09:07 PM
jefftallica's Avatar
I used to, until I removed the license plate frame. That was the only noise coming from that area. Now its solid.
Old Aug 21, 2008 | 12:16 AM
Invertalon's Avatar
Just add some double sided tape between the plate and plate frame. Then make sure you have two strips of door insulation behind your plate towered the bottom to stop the vibration rattle.
No more noise then!
Old Aug 21, 2008 | 04:22 PM
xBitchin's Avatar
yep. its your lic plate frame. that thing is only screwed-on on the top. you hear it to everytime you close d hatch.
Old Aug 22, 2008 | 09:21 PM
spiderxB's Avatar
might be gnomes... or elves. but 95% of the time it is gnomes.
Old Aug 22, 2008 | 10:46 PM
Chadodes's Avatar
If you have a 5-Axis body kit with TRd exhaust.. could be the exhaust tip hitting the rear bumper.
Old Aug 22, 2008 | 11:33 PM
lvbitwiz's Avatar
Definately Gnomes, lob a can of Bug-B-Gone in the back, that'll silence em for good!
(license plate BTW)
Old Aug 23, 2008 | 02:39 AM
curtisc's Avatar
I don't hear stuff when I close the hatch......but I do hear a bit of rattling/thumping from back there when I go over moderate bumps.
I will check to see if it is the license plate frame.
Old Aug 23, 2008 | 05:43 AM
madmarx's Avatar
I've recently been plaqued by a rattler in the right rear. I took off the license plate frame to eliminate that rattle but this one sounds like the door isn't closed all the way but it is. It only happens at low speed.
Old Aug 23, 2008 | 04:03 PM
rockthebeef's Avatar
Is everything secured in spare tire compartment? There are a few items in there that could work loose and make noise. Just a suggestion...
Old Aug 23, 2008 | 06:03 PM
Bench2's Avatar
Do you have lowering springs, new shocks, and/or a rear sway bar installed? Check your lower shock bolt. Mine kept coming loose to make noise under low speeds until I stuck some blue loctite on it.
Old Aug 26, 2008 | 10:46 PM
JoanMarshall's Avatar
Lock down the cargo cover in the rear.
Old Aug 27, 2008 | 02:34 AM
808-213-503's Avatar
I think the rear glass is doing the rattling, actually. No one else gets that vibrating reverb glass sound?
Old Aug 27, 2008 | 02:39 AM
madmarx's Avatar
Everything in the cargo bay is secure as well as the side latches. Ive tried the seats up down firmly latched with the seat belts secured opened and closed all the doors.
The car is lowered Ksport coilovers with sway bar; however i have checked all the bolts and lock rings. and I cant make the exhaust swing up to contact the rear bumper. The suspension did come with the disclaimer "race parts will make noise" It is just iritating not knowing for sure what it is.
Scionxa180
Sep 24, 2015 03:51 AM
StxArOne
Jul 13, 2015 06:25 PM
TinmanTC
Jul 12, 2015 07:53 PM
Mattlowe64
Jul 12, 2015 03:02 AM
SFXB
Jul 9, 2015 11:00 PM
