from moon roof to fixed glass
Old Aug 27, 2008 | 03:13 AM
boosthappy's Avatar
Default from moon roof to fixed glass
im just tryin to lightin up my tc and i was just wondering is there some were that i can get the fixed glass roof in 07 scion made a few tuner tc's with that fixed glass roof and some other light weight parts so the car would be lighter for racing please help if your able to
Old Aug 27, 2008 | 03:15 AM
equinox2355's Avatar
Are you going to be using it as a street car too?
I think the best bet (cost wise, and the most logical sense) would be to get a fiberglass or carbon fiber roof to replace the glass.
Old Aug 27, 2008 | 03:17 AM
engifineer's Avatar
Its not going to gain you much. The full glass roof plus mechanism only weighs about 70 lbs, so just getting rid of the moving parts in place of fixed glass most likely wont help a lot. You would really want to go with a carbon fiber roof replacement to make a big difference in that area.
Here are some links:
http://www.ilovebodykits.com/product...iber_Roof.html
http://www.grounddynamics.com/Templa...bFolderId=1853
http://www.directbodykits.com/Produc...Code=K060660FC
Old Aug 27, 2008 | 03:24 AM
Aroddalobster's Avatar
i have a spec roof for sale
Old Aug 27, 2008 | 03:28 AM
boosthappy's Avatar
how much
Old Aug 27, 2008 | 03:30 AM
BZinn1's Avatar
the kaminari CF roof would work and you should lose soem weight........and your wallet will be a lot lighter too.....but it sure would look hot.
Old Aug 27, 2008 | 03:33 AM
UNiT_xEr0's Avatar
DelMarVa
how much
click on his sig
Old Aug 27, 2008 | 03:59 AM
Elijahtc's Avatar
darn i wouldn't mind getting the CF roof for my BSP. wonder what it looks like from the inside. i never use my sunroof at all.
Old Aug 27, 2008 | 01:49 PM
engifineer's Avatar
From what I know it looks pretty unfinished on the inside. I think they developed it for Raamaudio (rick) way back. More of a track car item than anything else.
Old Aug 27, 2008 | 05:32 PM
AcidDrop's Avatar
obivously it'll look unfinished because you can't put the headliner back on unless you get it glued on.
Old Aug 27, 2008 | 06:44 PM
Scoobasteve4132's Avatar
I was looking into replacing the front and rear panels of the sunroof w/ a c/f panel... but after looking at it looks like you have to remove the roof to separate the panels...
Old Aug 27, 2008 | 07:16 PM
engifineer's Avatar
The deflector and main moonroof come off separately with no issue. I have taken the moonroof (slidiing portion) off of my car before. 4 Screws hold it into the mechanism. Not sure about the rear panel.
The deflector basicaly has pins holding it in.
Old Aug 27, 2008 | 07:21 PM
oh really!... ;) how'd you go about getting the reflector off?...
Old Aug 27, 2008 | 07:24 PM
engifineer's Avatar
I never took it completely off, just halfway to grease the pins on the deflector arms (which, by the way, is the source of many of the rattles and creaks people hear.. some thick grease will most likely fix 90% of that). The two deflector arms are attached with pins that have c-clips on them. You simply pop the clips off and pull the pins out to release the top of it. I am pretty sure you can take the lower hinge off fairly easily as well, but I havent look as closely at that.
For the front moonroof panel, look on the inside of the tracks from inside the car and you will see the 4 Torx screws that hold it on.
Just dont drop them when you take em out :D
And happy bday by the way.
Old Aug 28, 2008 | 01:12 AM
thanks dude... imma gonna have to look @ that this weekend...
Old Aug 28, 2008 | 02:28 AM
Dr_Isotope's Avatar
Six T25 screws and the deflector comes off. I've had mine off several times for cleaning (and once to wrap in vinyl). Engi is right on about the noises-- I glooped all of the pivot points with silicone grease, and it's quiet as can be,open or closed, at any speed.
The glass weighs nothing-- if the deflector is 2lbs, I'd be amazed.
Old Aug 28, 2008 | 12:07 PM
wow, really... figured as thick as it is, it'd have some weight to it...
Old Sep 2, 2008 | 06:28 AM
divisii's Avatar
I think I read @ that one-off CF roof that was mentioned was only good for losing 12 lbs or so.
I'm wondering why the Kaminari roof is rated off-road only.
Ha, the ultimate 'panda'- CF hood, roof, & hatch!
Old Sep 2, 2008 | 06:31 AM
The weight isnt where I see the most problems. The problem I see is if you make the upper part of the body too stiff, you will break the glass. If you have a CF roof you can make the body stiffer and it wouldn't be prone to breaking like the glass would.
I would only do this if I was going to be racing and needed to really stiffen up the ride. Other than that its pretty pointless and it reduces visibility!
mc1114
Scion tC 1G Aero & Exterior
Apr 23, 2020 10:34 PM
evolving_machine
Feb 27, 2015 09:53 PM
evolving_machine
Jan 13, 2015 08:04 PM
pier0723
Scion tC 1G ICE & Interior
Dec 3, 2014 03:38 PM
Risen_Son_Racing
May 6, 2005 02:31 PM
