problem with initial turbo start up
Old Sep 3, 2008 | 06:57 AM
Angry_Celi_Guy's Avatar
Default problem with initial turbo start up
hi everyone, i just installed my greddy kit. its got 550cc injectors, fic and gunna use ngk brk7eix-11 plugs. i had a set of denso ik24's but i believe i fouled those.
i got a base map from church tuning but my car wont idle properly or stay on by itself. when it does kinda idle the rpms are all over the place and vac is usually between 10 in' and 0, the car almost sounds like its misfiring altho i dont have a cel. when i connect my laptop to the fic and use the gauge function the highlighted cell dips down into a portion of the map that is zero'd out.
if anyone could help it would be appreciated.
Old Sep 3, 2008 | 07:10 AM
GReddy_tC's Avatar
You need to calibrate the F/IC. You can ask paulDezod or joeDezod how to do that..
Old Sep 3, 2008 | 08:11 AM
aen's Avatar
aen
it's the zeros too, what base map is THAT?
there shouldn't be any zeros.
can you send me the map? i'll send you a real basemap and also send you a batch of maps that you can try out
Old Sep 3, 2008 | 02:26 PM
garabaldy's Avatar
which map are you seeing zero's? sounds like a vac leak...
Old Sep 3, 2008 | 04:19 PM
aen's Avatar
aen
try unpliugging the f/ic completely and seeing if it starts up. if it does, it's the tune/calibration if it doesnt' then it's a vac leak
Old Sep 3, 2008 | 04:42 PM
ill try to get the map to you aen, can you pm me your email?
Old Sep 3, 2008 | 05:19 PM
aen's Avatar
aen
ifeeldope@gmail.com
i lah-hazy.
Old Sep 3, 2008 | 05:54 PM
cool thanks, i gotta go to work in a couple mins. i should be able to email the map to you around 5 or 6 pm pst.
also should i regap the NGK's or just put them in when i get them?
it was dipping into the 0's of the ign timing map.
Old Sep 3, 2008 | 06:04 PM
aen's Avatar
aen
ign timing should be at 0
fuel shouldn't be at 0
Old Sep 4, 2008 | 04:04 PM
enjoithis's Avatar
theres 5 maps on the FIC,
I ran church's map on my 550cc set up too, idled fine, and there arent any 0 out spots on the fuel map near idle. Ign timing should be 0 at idle (on the map) the car is acutaly running like a 15 degree advance from the factory though. at high boost you should hit negatives but only under boost.
gap your plugs to 32 (i think)
Old Sep 5, 2008 | 02:27 PM
i thought the plugs should be gapped to .040?
what should the plugs be gapped to?
i got an appt tomorrow morning with church, hopfully he can figure it out.
Old Sep 5, 2008 | 02:36 PM
Ace83's Avatar
Ronin Scion
yup with piggybacks a value of 0 means you are running the stock tune like the box is not altering any, if only we have a software where we can see the stock map or 3 graph then it would be easier for us to understand it better...
Old Sep 7, 2008 | 05:28 AM
lock please
Jordly221
Feb 13, 2019 05:29 PM
darkshadowofxdeath
Feb 11, 2015 05:38 PM
missing_image
Feb 7, 2015 07:18 PM
cid_mcdp
Jan 5, 2015 02:45 PM
fluxingnation
Dec 26, 2014 04:28 PM
