problem with initial turbo start up
hi everyone, i just installed my greddy kit. its got 550cc injectors, fic and gunna use ngk brk7eix-11 plugs. i had a set of denso ik24's but i believe i fouled those.
i got a base map from church tuning but my car wont idle properly or stay on by itself. when it does kinda idle the rpms are all over the place and vac is usually between 10 in' and 0, the car almost sounds like its misfiring altho i dont have a cel. when i connect my laptop to the fic and use the gauge function the highlighted cell dips down into a portion of the map that is zero'd out.
if anyone could help it would be appreciated.
cool thanks, i gotta go to work in a couple mins. i should be able to email the map to you around 5 or 6 pm pst.
also should i regap the NGK's or just put them in when i get them?
it was dipping into the 0's of the ign timing map.
theres 5 maps on the FIC,
I ran church's map on my 550cc set up too, idled fine, and there arent any 0 out spots on the fuel map near idle. Ign timing should be 0 at idle (on the map) the car is acutaly running like a 15 degree advance from the factory though. at high boost you should hit negatives but only under boost.
gap your plugs to 32 (i think)
missing_image
Feb 7, 2015 07:18 PM
cid_mcdp
Jan 5, 2015 02:45 PM
fluxingnation
Dec 26, 2014 04:28 PM
