How do you turn off the "Maint Req'd waringing light&qu
Old Dec 16, 2004 | 10:25 PM
DaHamma's Avatar
Default How do you turn off the "Maint Req'd waringing light&qu
I recently got my oil change before the 5k miles that is set in the computer. I did this becasue I was going on a long road trip and wanted it changed before I went. I would like to know if anyone knows the procedure to turn off the "Maint Req'd waringing light"? Also, if you run through the correct procedure does this turn off the warning light for good or just til the next 5k miles? I looked in the owners manual, however I could not find it. If it is indeed in the book, if you direct me to the page. Thank you.
Old Dec 16, 2004 | 10:46 PM
BlkSandPrlTurbotC's Avatar
Put your ignition on the "on" position, hold in your odometer switch, start your car, keep holding in the swtich, then it will blink off, once it does your set to go. had the same problem but I went to my toyota dealership to show me, it's really easy
Old Dec 16, 2004 | 11:37 PM
Wolo's Avatar
Its in your owner's manual, somewhere around 87-90 I think.
Old Dec 17, 2004 | 01:12 AM
DaHamma's Avatar
THANK YOU!!
Old Jun 13, 2010 | 05:46 PM
escoles's Avatar
Default What if these procedures don't work?
I've tried both the the procedure outlined in the manual and the one outlined here (they're a little bit different), and neither works. Has anyone else found any other way of turn off the MAIN REQD light?
Old Jun 13, 2010 | 05:57 PM
RoboCop's Avatar
Turn car off. Press and hold the odometer reset button. Turn car on. 5 lines will appear and they will blink and disappear. Once all have disappeared, let go of odometer button.
Old Jun 13, 2010 | 06:38 PM
escoles's Avatar
As I said, that procedure doesn't work. I see no observable reaction when I perform these steps. I've tried variations on this which include just turning the switch off and on (which is what it says in the manual) and turning the car off an on.
None of these procedures have had any observable effect on the MAINT REQD light. Does anyone know of any other procedures that might?
Old Jun 13, 2010 | 07:00 PM
yellowxhoodie's Avatar
http://www.thesciontc.com/faq.html#c7
Old Jun 13, 2010 | 09:22 PM
cT_Finest_tC's Avatar
This worked for me and I stopped with 2 dashes left. Hope my light comes back after 3k miles.
Old Jun 14, 2010 | 02:25 AM
escoles's Avatar
Thanks, that's helpful. I had actually found a mirror of that FAQ and made it work.
Cross-posting your link (which looks more canonical than the one I found) to the other thread where I brought this up:
https://www.scionlife.com/forums/sho...=1#post3597332
StxArOne
Jul 13, 2015 06:25 PM
rancur3p1c
Jul 12, 2015 07:59 PM
Mattlowe64
Jul 12, 2015 03:02 AM
boxcar87
Jul 12, 2015 12:16 AM
setpol
Feb 17, 2015 11:33 PM
