needle spiking? cel?
Old Sep 4, 2008 | 06:51 PM
FKasperkhan's Avatar
Default needle spiking? cel?
So i was driving the other day and i had a CEL so i stopped at auto zone and they said it was the MAF sensor, So i went home and unplugged my negative and let it sit there over night so when i plugged it back in today, my passenger window doesnt roll down by the driviers side so i have to lean over and use the passenger side. MY car at a cold start idled at 2550 RPM and when i drive and put it in neutral, it idles at 1500. and the needle starts to spike? why does it do this?
i have a fujita f5 CAI
Old Sep 4, 2008 | 06:55 PM
B_Real45's Avatar
The power window thing is normal - it'll get back to normal soon. Technically you're supposed to initiate the power windows.. I'm not sure how.. but there's a way to do it. Mine just comes back working like normal in a day or so.
I'm not sure why your idle is like that though.. sorry.. perhaps your MAF is just bad. You can get one a Advanced Autoparts for $80+ and core charge.. you get the core charge back after you give them your stock MAF.
Old Sep 4, 2008 | 06:56 PM
SquallLHeart's Avatar
read manual. reset windows.
as far as your maf.. dunno dude.
my intake did this at first and they said to let the car idle for 5 minutes for the comp to remap the air amount or something. But i was thinking about putting on my stock intake and taking it into the dealer to get it serviced uinder waranty and then swap it back with the CAI when iu get it back.
Old Sep 4, 2008 | 07:39 PM
SengTC3's Avatar
X2
How to fix the window is in the manual. Supposedly you got to let your car idle for 10 minutes or so.
Old Sep 4, 2008 | 09:09 PM
toyoguy27's Avatar
hold your window switch in the up position for 15 seconds with key on,
Old Sep 4, 2008 | 10:05 PM
engifineer's Avatar
RTFM for the windows.
The CEL codes dont mean "Sensor bad".. have them tell you which code is set. It could mean a bad sensor, or something causing it to read the wrong thing. For example, if you install the wrong year model intake you will end up with MAF codes even if the MAF is not bad. The worst thing to do is to go swapping out parts until you fix it.. that just costs you more money than it should. At least find out the code and maybe we can help you figure out what is going on. What year model is your intake from, and what year model tC do you have?
Old Sep 5, 2008 | 03:50 AM
Rawkerstatus's Avatar
hahahah this is totally gonna go into my sig.
k i fixed this one.. now i needa fix my sig.
Old Sep 5, 2008 | 04:12 AM
ah.. dude.. i fail at puttin qoutes in my sig.
Old Sep 6, 2008 | 03:52 AM
x_Batman_x's Avatar
have you tried cleaning the MAF sensor? buy MAF sensor cleaner and give that a go...
Old Sep 6, 2008 | 03:59 AM
senseiturtle's Avatar
1) Read manual, reset windows. Reset sunroof.
2) Get the code from autozone. Reset CEL, see if it comes back. If it does, then research it... try cleaning MAF sensor first (if it's shot, it's shot)... then buy a new one. Very easy to replace yourself.
3) High Idle from a cold start is actually normal, and can be exaggerated with a CAI. The idle then changes under varying load conditions (when you put it in drive, neutral, etc.)... and is also changing based on the "warmup state" of the motor.
If your MAF sensor is truly broken, then you'd be running open-loop all of the time. Note if you get a huge drop in power and gas mileage. This could also explain the janky idle.
Old Sep 7, 2008 | 04:07 AM
yeah i tried to reset it again but it comes on after a few hours or a day or so, i have an 07 tc with a fujita f5 intake but its for an 06-07 so idk why the cel keeps coming on
Old Sep 7, 2008 | 06:38 AM
sciontc_mich's Avatar
have you cleaned the MAF sensor with MAF sensor cleaner yet?
yhwhdesign
Jun 11, 2021 03:34 PM
MeDizzy
Oct 8, 2015 03:31 PM
paisatronix
Sep 5, 2015 04:13 AM
xb4lf
Apr 4, 2015 07:15 PM
lovemyxb333
Apr 3, 2015 04:24 AM
