alright rpm problems!?
Old Sep 13, 2008 | 05:26 PM
turbotc06's Avatar
Default alright rpm problems!?
ok so i really do not get this at all and i read a few others but i have no boost leak or exhaust leaks .....
but heres the problem I am running stock injectors and a step colder plugs ....
sometimes the car will rev through to rev limiter ...other times she will get stuck between 35-4500 rpms and will just stick ... i unplugged greddy emanage ultimate so that is not the cause
I think if I go 2 step colder plugs it should fix this problem should it not?
cause im only running 5.5 psi now instead of the 9 i was running before
HELP this is driving me nuts because the car would run awesome if it wasnt for this problem!
Old Sep 13, 2008 | 05:28 PM
AcidDrop's Avatar
what kind of turbo are you running?
Old Sep 13, 2008 | 05:33 PM
turbotc06's Avatar
16g with dezods intercooler kit and zpis log manifold
this is stumping the hell out of me im thinking the plugs just arent firing strong enough ...or maybe my coil packs?!
Old Sep 13, 2008 | 05:41 PM
SoFloTC's Avatar
why the heck do u have stock injectors still
Old Sep 13, 2008 | 05:45 PM
AcidDrop's Avatar
so your turbo is custom then, yes why are you still running stock injectors and do you atleast have a wideband. the sparks aren't the problem and idk why you decided to tun the car with stock injectors, you should of just waited because then you'll have to pay all over for a retune....just saying.
Old Sep 13, 2008 | 06:07 PM
NVMyTc's Avatar
Did you get any tuning done or are you on a base map?
Old Sep 13, 2008 | 07:23 PM
turbotc06's Avatar
greddy is unplugged so its on the ecu .... and its gotta be spark or something because in boost she runs down into the 12.1-12.7 afr range
zfxp
Apr 2, 2015 06:51 PM
zfxp
Mar 26, 2015 02:29 PM
nastytc
Scion tC 2G Aero & Exterior
Jan 27, 2015 03:50 PM
Jaywade24
Jan 21, 2005 03:44 PM
2fixA
Sep 25, 2003 08:06 PM
