Oil Catch Can
Old Oct 5, 2008 | 02:56 PM
RichTc's Avatar
Default Oil Catch Can
Hi,
I just purchased a greddy oil catch can which I was just about to install, when i realized that the valve cover has two breather hoses (one to intanke manifold one to intake). I read around a little while about it and it seems like most people are just running the catch to the one through the intake?
So my question is, should i modify the can to add two more ports to vent both, instead of just one? Should i buy a new one with two? or should i just install it to the intake house?
Any thoughts would be appreciated.
Thanks!
Old Oct 5, 2008 | 03:17 PM
jackotamo's Avatar
You attach the hoses from the exhaust outlet from the valve cover (the one that currently has the hose to the intake) to your catch can and then from your catch can to your intake( not the manifold). You can run 2 catch cans if you want, one for the intake valve exhaust too, which most peoply dont see necessary since blow by really doesnt occur there. Im running a single for the exhaust.
Old Oct 5, 2008 | 04:02 PM
RichTc's Avatar
So the blow-by doens't occur in the breather tube going to the intake manifold? I read the dc 3 install
http://blog.scionxtc.com/blogs/archi...catch-can.aspx
and it looked like the tube to the intake manifold had some slidge in it (as he indicated in his write up).
I was thinking about hunting down two more fittings and modifing the catch cna to work for both hoses.
Has anyone done anything like this, or is it really not necessary?
Thanks!
Old Oct 5, 2008 | 04:30 PM
SoFloTC's Avatar
ive rarely haerd of anyone doing it with the catch can... everyone just does the 1 hose to where it would usually go to the intake.
Old Oct 5, 2008 | 08:22 PM
purplenitroustc's Avatar
exactly what he said above.. leave the other hose alone
Old Oct 5, 2008 | 09:54 PM
JL56TC's Avatar
here read this
https://www.scionlife.com/forums/vie...570&highlight=
Old Oct 5, 2008 | 10:17 PM
RichTc's Avatar
ok.
makes sense as puttin it on the front one would stop oil from going throught the turbo.
thanks.
Old Oct 5, 2008 | 10:22 PM
JL56TC's Avatar
yep... try and search next time though b4 you post
Old Oct 6, 2008 | 01:28 PM
BLUEMEANIE's Avatar
Team Hamster
I'm using the Saikou Michi DC3 dual catch can ... when I drain mine I get almost the same amount of oil from both cans, meaning there is about the same amount of blow-by in both vents.
Old Oct 6, 2008 | 10:01 PM
jetlounge's Avatar
hmm. saikou michi. now where have I heard of that before?
Old Oct 7, 2008 | 09:33 PM
BLUEMEANIE's Avatar
Team Hamster
^ haha.
Old Oct 8, 2008 | 09:35 AM
kirk212's Avatar
Yea i have both ports filtered with 2 different catch cans, and i notice blow by on both of them. I dont think one cam blows by more than the other. For me its about the same.
And let me tell you..... I have the greddy catch can.... and the hose that came with it suck. You should look into buying some proper sized vacuum hose. What they supply bends and crimps which restricts airflow, which gives bad AFRs during idle. Go here:
www.BoostController.com
I got 8ft of 10mm , and 6ft of 13mm vacuum hose. That was enough to do the trick. And they have about 4-5 different colors to choose from .
Old Feb 23, 2009 | 04:30 PM
ippskidder's Avatar
1UP Crew
thx for the info!!
Old Feb 23, 2009 | 05:28 PM
OuterHeaven's Avatar
Just to show that you should vent both ports, here is a thread from ScionDad from several years ago. Just so you know he already had the front drivers side port vented and these are just the results from the rear one on the intake manifold being vented.
https://www.scionlife.com/forums/vie...&highlight=egt
I wish they would have further discussed the topic. Maybe someone could do more testing if they were willing enough.
Old Feb 23, 2009 | 06:46 PM
CarbonXe's Avatar
This thread made me realize that I've gone 4 months without any form of catch can .
pro710
Dec 27, 2023 03:34 PM
mudguy
Oct 22, 2015 04:31 PM
Klashan
Sep 24, 2015 12:39 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
BlingSlade
Sep 5, 2015 08:52 AM
