fuel pressure regulator
Hi guys i'm building a custom setup with a T04E turbo and looking to achieve 250 WHP. my question is. Do i need to change the stock fuel pressure regulator ?? what kind of fuel pressure regulator do i need ?? BTW i've allready change the fuel pump to a 255 lph walbro.
I would assume you'd have to change it out if you got bigger injectors and a high output fuel pump... Not sure though. Or maybe you only change it out when you upgrade to a high flow fuel rail. I'm curious to know also.
To answer you question, no you don't need an aftermarket FPR for what you are doing. To clarify, our FPR are in-tank units (you plugged your walbro into it) that just bleed off the excess pressure before it even leaves the tank (approx. 50psi). You will only need an aftermarket FPR if you modify you fuel system to a return setup.
a relief valve is a pressure regulator, it regulates the pressure by relieving it.
gedster314
14
Nov 17, 2018 02:56 PM
